Claims vid @ 1.37 volts, but it's hard to really know without them throwing it in an ATX. I really wish we had a release date on the Asus, which would make my decision much easier, but worse case scenario I can pick up the Asus and send back the Asrock. I just hope the Asus is out in the next 30 days
Any word yet on a release date for the Asus board?
ASRock
Z77 E-ITX (ASRock)6-phase VRM (CPU); 4 SATA (2 x 6Gb/s); RealTek ALC898 audio; Broadcom NIC; Rear panel: 4 x USB 3.0; 2 x USB 2.0; mPCIe slot; wi-fi
i guess no ETA on that Gigabyte board.. does it really offer much over the ASRock Z77E... nothing i can see?
so i should be good to go with the ASRock board then it seems...i want to do anotehr i5 and OC a bit, at least 4Ghz.. in an miniITX set up
OCaholic has a preview and a lot of great images of the new board. The site is in German, so you'll need to translate it; you can also check the original post for a few of the specs.
The new Gigabyte mobo will do 4GHz easily enough I'm thinking. It just wont do high high end overclocking from what we are hearing so far but its all unproven so far. We'll need to see some actual tests first. Gigabyte makes some nice quality stable mobos so I don't think it will be a dud. If you want something now then ASRock or Asus will be your best options.
Why is it so hard to find the following in one mini-ITX board:
VT-d Support
16GB+ ECC Support (honestly not even a deal breaker)
2x Gbit LAN Ports
VT-d Support
2x Gbit LAN Ports
Hopefully this Ivy Bridge batch yields something better though I haven't seen it yet.
The closest two options today are the Jetway JNF9A-Q67 or the Intel S1200KP.
Are you sure? Intel lists the VT-D as no go on the z77 chipset. Has anyone tried an Ivybridge on the JetWay JNF9A-Q67?well asrock will do VT-d and 16GB non ECC ram then you have get yourself a dual Gbit LAN card.
if you intend to use the PCIe slot for GPU then you will need something like a PE4L / PE4H (diy vidock) card for your Gbit LAN and have it attached to the wifi slot
fwiw, I run an Asrock mATX Z77 and it has an option to enable VT-D in the bios.
Has anyone tried a Z77E-ITX w/ ECC memory + a Xeon?
Here's a link to the previous thread I started about this...I'd also like to know about this and after reading the manual & a few comments, it looks like this board has zero options for voltage adjustments outside of the memory. How can there be no VCore adjustments on a Z77 board? I planned on picking one up, but this has me very confused.
has anyone grabbed the gigabyte board, i see it is on sale now
http://www.amazon.com/Gigabyte-1155...=UTF8&qid=1354772718&sr=1-2&keywords=z77e-itx
tonymac though saying it only has a 4 phase power..
VT-d Support
2x Gbit LAN Ports
