itunes uninstall killed vista
Discussion in 'Operating Systems' started by Version_3, Feb 13, 2008.
  1. Version_3
    Version_3 2[H]4U
    4,085
    Nov 19, 2007
    Last night was just freaky.
    I went to re-activate my copy of vista since it deactivated due to hardware changes, and I found that it was already reactivated. Ok, weird, but cool. Next, I did updates. Did the usual song and dance of update, reboot, configure, reboot, configure, login. Cool. I decided to remove iTunes from vista because I want to put it onto another machine.
    So I uninstalled it, then did the recommended reboot. Upon hitting the boot select menu (for vista or xp x64) and upon choosing vista, it tells me that winload.exe is missing.
    I hate vista, and have no remorse about getting rid of it, but can I restore a backup copy of winload.exe from somewhere? Where in Vista would that somewhere be? Its a non-SP Vista Business edition.
  2. xxEIEIOxx
    xxEIEIOxx 2[H]4U
    2,281
    Feb 1, 2008
    You may try what is posted here http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=801428&SiteID=17 though I can't claim to have tried it, I haven't had this problem. I wouldn't necessarily blame Vista here, as I have seen many problems with Apple software on Vista (iTunes, Quicktime, Bonjour). All of my problems with Vista disappeared when I got rid of all of them.
  3. milkweg
    milkweg [H]ard|Gawd
    1,524
    Sep 6, 2007
    I had Acronis True Image do the same thing to me on Vista when I created a secure zone on my HDD with it. The fix is to put in your Vista disk and choose repair option. That fixed it for me anyway.
  4. Version_3
    Version_3 2[H]4U
    4,085
    Nov 19, 2007
    Oh I know iTunes did it. "iTunes uninstall killed vista"
    I also fixed the issue. From xp, I searched the vista drive and found old copies of winload in sxs folders. I grabbed the most recent one and slapped it into system32. Works now.
  5. Nenu
    Nenu [H]ardened
    18,588
    Apr 28, 2007
    I had the same problem with a clients PC when he wanted to get rid of it after his daughter installed it.
    We found that uninstalling killed all internet, thats scary because it must form part of the route that all your traffic flows through!
    We verified the issue by rolling back to before installing it, put it back on and uninstalled again, same problem.
    The cure we had was to restore the sytem with System Restore to before when it was installed.
    This was a year ago so the post above is better advice :)
  6. Cyrilix
    Cyrilix 2[H]4U
    2,188
    Jan 21, 2005
    I have not tried to uninstall iTunes yet, but this is absolutely terrible. To think that a music playing application could cause that much damage is pretty scary.
  7. dreamer3kx
    dreamer3kx Limp Gawd
    454
    Oct 28, 2007
    itunes is the devil on a windows machine,
