oldschool_7522
- Dec 13, 2016
The G602 is 250 hours on two AAs.
I get 5-6 months of mixed use (performance and endurance) using a 2200ma rechareable battery (just one cause i like the weight better) in my g602
The reason I need a wireless would be to sit on my couch and play on my television. Have they solved the distance problem with connection because that would be the only reason I need to be wireless.
The problem isn't wireless.
The problem is 99% of mouse designs these days are fucking stupid.
All sharp edged and shit. Logitech has gone way overboard with it.
Go back to the proven design of the MX518 and just update the electronics and leave perfect alone.
My thoughts exactly.No.
End of discussion.
Or gasp... have a dock you stick the mouse in to charge it when not in use.Why can't they also make a mouse pad that wirelessly CHARGES the mouse? Think about it.
This article seems to back you up: http://www.pcgamer.com/how-logitech-aims-to-prove-wireless-mouse-latency-is-a-thing-of-the-past/Wireless have been a worthy replacement of wired since Logitech G7, when they introduced the 1000hz polling rate, 1ms delay.
Stop nagging about that and get over it.
Bring back the Logitech MX1000 or a equal variant thereof. I'm sick of lightweight 'gaming' mice which feel like a feather in my hand. And it better be reliable. The most reliable mouse I have ever owned was the MX1000. Currently using a G700 and it is close to a MX1000 yet not quite what I'm comfortable with.
This article on PCGAMER was just fine but I'd kind of like to see HardOCP do an empirical analysis of wireless mouse latency with the current generation of wireless mice. Both Logitech and ROCCAT have recent entries into the wireless mouse arena that claim to have 0 lag. Make it so!
I'm not making the move, too many factors moving against wireless to get me to move from wired.
Whats the downside of wired mice? you have a stupid wire?
Yes, the wire is stupid.
Someone like myself who game on a Ikea Galant and have their PC on another stand, the mouse cable will need to be extended, increasing latency aswell.
Wireless is less of a headache for those who have larger than average desks.
If your PC is within 2ft. of your mouse and monitor, then I can see your POV.
People go with a wired mouse for many reasons. As a gamer, it's mainly cause of latency. But also not needing to charge it or worry about signal interference. Also the battery in the mouse makes it heavier, plus wired mice are cheaper. Some people will even go as far as to use PS/2 port to reduce input lag.
So yea, it's time to embrace my dick.
People said at one point dual cores were enough for gaming, 1080p was enough, 4gb of ram was overkill and onboard sound would never be a viable option for gaming audio.
Times change but the skeptics tend to hold on until they can't anymore. Then in secret, upgrade and wonder why they didn't do it sooner.
That could be an interesting test. I wonder how you'd do it.
Probably high speed camera with both a CRT monitor (to avoid monitor input lag) and the mouse in frame at the same time, or something like that.
Seriously though, as has already been mentioned, a lot of issues with wireless are due to the older technology. Try a g900 out. I'd be very surprised if you could tell the difference.
Nobody said that. At least nobody smart.People said at one point dual cores were enough for gaming,
Probably the same idiot that said dual cores were enough.1080p was enough, 4gb of ram was overkill
And that's a lie cause we know the best sound card ever produced was the SoundStorm on the Nforce2. In fact modern Sound Cards are worse because they instead use the CPU to process sound. So if anything onboard audio has gotten worse. The exception is the DAC has gotten better for onboard audio, but that doesn't change that onboard sound is just basically the DAC. The only sound cards today that even do hardware audio acceleration is Creative cards, and they rarely make it onto motherboards.and onboard sound would never be a viable option for gaming audio.
You're using simple evolution in technology to compare that wireless is the next natural step in evolution over wired. It isn't that simple, because wireless is inherently problematic. Those problems aren't going to disappear. How many network admins wire their infrastructure with 100% wireless? Almost none. Why? Cause wireless is slower, insecure, breaks often, and costly. That can all apply to wireless mice, and nothing you say will change that. Not including the problems wireless mice have like recharging and extra weight for the battery. And batteries go bad eventually, and I bet most mice don't exactly allow you to replace it without voiding a warranty sticker, which btw those warranty stickers are illegal on devices to begin with.Times change but the skeptics tend to hold on until they can't anymore. Then in secret, upgrade and wonder why they didn't do it sooner.
Or.. like the MX Master, have it able to be charged through a USB cable so you can still use it/charge it if the battery goes dead.
yup, I use this mouse and its fantastic. Going on 2 months now with the same battery lolGreat battery life, you can use either regular or rechargable batteries. Sweet mouse.
http://gaming.logitech.com/en-us/product/g602-wireless-gaming-mouse
I literally can't tell the difference—except that I'm free from the weight and distraction of a cable.
