zamardii12
- Jun 6, 2014
This is everything I got for the build.
That GPU come with the needed adapter for older PSU.You will need 12VHPWR for that GPU which can deliver up to 600 watts of power to the GPU alone.
I'd recommend the Corsair HX1200i
The GT is simply not compatible from what I can see at 1st glance.
So should I be sending the PSU back? Sounds like it from your comments, but I haven't run into any issues yet.That gt is decent but not something I would pair with a high end rig going forward.
If you already have it, roll with it. I was under the impression you were buying, not boughtSo should I be sending the PSU back? Sounds like it from your comments, but I haven't run into any issues yet.
That's a great unit.So I ordered this 1200 Watt EVGA Platinum PSU instead and will return the other one. Should be better than my 1000w Gold. I've never purchased a "platinum" PSU before.
Aio cooler for sure.
Might want to rethink your CPU.Aio cooler for sure.
Thread is from 2 months ago. What do you think?Might want to rethink your CPU.
Hopefully you didn't ordered yet.
You never know, I been planning mine for a while.Thread is from 2 months ago. What do you think?
