Breath_of_the_Dying
- Jan 8, 2007
I have a sceptre X42 1080p naga. This TV works really well and supports 1920x1080 resolution with VGA input. I'm really happy with my x1950pro purchase save one issue.
When I reach the logon screen of XP the screen goes blank. I've seen reports of it happening on other LCD monitors too.
My solution is to let XP startup and keep the cable unplugged from the video card. Once I'm in the logon screen I plug it it. From there it works, but the resolutions are all messed up. When I'm at 1920x1080 resolution, my TV sees 1240x1024 resolution and I can Bump scroll across the entire desktop. To fix that I first set the resolution to 1920x1080, and accept. Then I turn on extend my desktop to the second monitor (which doesnt exist), and lower the resolution on the main monitor. When I hit accept, XP makes that sound like a new device was installed. I decline the changes, putting it back at 1920x1080 resolution, and from there it works perfectly!! All is well until I turn my computer off and have to do it again.
Recap of steps
1) Turn on computer and leave the vga to video card cable unplugged
2) Plug it in on the logon screen
3) Change resolution to 1920x1080, accept
4) Extend desktop to second monitor, lower resolution on main moniter
5) Cancel and everything is good!
This is getting very annoying to do, and I was wondering if anyone knows a solution to it. I dont have to do this in safe mode, so I'm guessing is a driver issue (using 7.1) Do you think the only solution is waiting for new drivers?
Thanks in advance
Recap of steps
Thanks in advance
