The Lurker
- Jul 1, 2001
I need a sanity check. For the longest time I was able to flawlessly connect from my Android phone to my home based PFSense using Open VPN. Sometime earlier this year this stopped working. I am guessing right around the time I changed phones (S21 to S24). The ovpn client log file on the phone does mention "Endpoint address family (IPv6) is incompatible with transport protocol (UDP4)". After a lot of troubleshooting and reading the only conclusion I can make is that the issue is caused by the phone now being assigned an IPv6 but my home internet is still on IPv4. However, if it is then I don't understand why. Shouldnt Tmobiles network provide the proper translation allowing the two to communicate? I have tried to ping the server with the phone and the ping does reach it. I have tried to enable IPv6 on the WAN port and on the LAN as well. I have even tried to allow PFsense to grab an IPv6 from Verizon but they dont support that everywhere at this time.
Am I correct here, is the issue IPv6 vs IPv4 or something else?
The only thing I can come up with next is to setup a IPv6 to IPv4 tunnel but I want to make sure I didnt overlook something a lot simpler before I go down that rabbit hole.
