Is this Direct CU 290x fan supposed to be bent?
glenn37216
 Does anyone know if this rear fan on this Direct CU 290x card is supposed to be slightly bent like this ? Ive owned several other 290x brands and I've never seen this before. Fan spins at the proper rpms....should I be worried an or set up an RMA?
Any thoughts appreciated ! Sorry.. Phone pic hosting is buggy.. ��.
https://docs.google.com/file/d/0B1c9Y3tDA5HEbmJ3UHFLVTBUc1k/edit?usp=docslist_api
https://docs.google.com/file/d/0B1c9Y3tDA5HESlhoNVNHdXRKT28/edit?usp=docslist_api
From the pictures you can see the fan is slightly tilted. Probably 2mm lean.
gungravevn
Does it make any noise? If you dont mind the downtime then set up a RMA. If it doesnt make any unusual noise at high speed then you are just fine.
glenn37216
It's completely silent. I've seen older gpu's with this anomaly but not higher end cards. I guess I can live with it ....I was hoping this was done on purpose by Asus...some ultra elete cooling method. : p heh guess I'm just too hopeful. Thanks for the response guys.. :)
