BigBadBiologist
- Mar 19, 2001
I have a Powerbook Ti 400 (res:1152x768) in which I replaced the screen. Unfortunately, I replaced it with a screen from a DVI model powerbook (res: 1280x854) so there is junk on the right and bottom of the screen. There may be an issue with the interface, but I'd like to try to at least just switch the resolution to a higher one. Unfortunately, the control pattern only lets you select up to 1152x768. So I was hoping to find something like Multires for a PC which lets you select nonstandard resolutions.
