I know I can disable Auto run for a CD-rom but is there some way to disable autorun for a specific USB hard drive?
I like to use autorun with my USB flash drive etc. just not with the hard drive (the more stuff I get on it, the longer it takes to scan through all the crap when I plug it in).
I am sure I can hold the Shift key when I connect it but that's not what i want.
I found that I can tell it to take no action but the thing is it still scans through all the content of the drive each time you plug it in. It's a 200 gig HDD in the enclosure so that's going to take a looong time eventually.
I'm running Windows XP Professional.
I hope this post is at least somewhat clear. Ask for clarification if neccessary.
Thanks for any input.
