Is there a device that can do the following over a network?
aakast42
I have a computer stuffed with tons of video and music. Off the top of my head it contains videos ranging from >30GB 1080i mpg and .ts files, 720P mpg and .ts files, XviD files of varying sizes (mostly DVD rips), some DivX (also mostly DVD rips), h.264/x.264/Nero Digital AVC files of resolutions as high as 720P (all use CABAC.. most are main profile there maybe 1 or 2 encoded in high profile). So along with the audio (FLAC, mp3, and AAC), again off the top of my head I have media in the following container formats: .ts, .mpg, .avi, .mp3, .m4a, .mp4. Also, I have a few DVD ISO's laying around.
I really, really don't want an HTPC in my TV room. I have no desire to have any PVR functions an HTPC may be able to perform or whatever. What I'm looking for is a box that can hook-up to a home theater system / HDTV and allow me to access and play the previously mentioned videos over a network.. canbe wireless g/n or 100/1000 ethernet... doesn't matter to me as long as it works. It seems like that is a tall order for an STB type of box but maybe there are boxes that one can somehow install additional codecs in order to play all of these media types?
Ideally, I picture a box with both ethernet and wireless options, an MCE interface or similar that makes browsing through available media easy, is a small form factor, doesn't make much if any audible noise, and has connections/ports for things like HDMI, SPDIF, component, composite, S-video, or some acceptable combination there of that can make the videos on a standard windows shared folder watchable. Is there such a device? Are the processing capabilities too do the h.264/x.264 and 1080i .mp and .ts files too much for anything but a true HTPC? Is there a way for the decoding to be done at the other end (the desktop) and have the video streamed raw over the network? I simply have no clue as to what types of devices are out there. Thanks in advance and I really apologize for my newbieness on the subject. I tried finding this info on my own but was either unable to understand what exactly certain devices did or became further confused.
Tomson
I think he'd have trouble playing dvds over the network through an extender as they don't support vobs.
Have you checked out the popcorn hour or tvix products?
vischo
No but it should play the majority of these other filetypes he has :
mpg and .ts files,XviD DivX h.264/x.264/Nero Digital AVC FLAC, mp3, and AAC .ts, .mpg, .avi, .mp3, .m4a, .mp4.
LhasaCM
You could also look into the Sage HD Media Extender (http://store.sagetv.com/Merchant2/m...e=SOS&Product_Code=STX-HD100&Category_Code=HD). That should work as well as the other extenders out there, but also would support DVDs ripped to the hard drive. $200 for just the hardware, $250 for the hardware/software (if you don't already have a current SageTV license).
(I haven't tried the HD extender - I had their SD extender in use a couple of years ago and it worked great.)
