Is there a best 1080ti card? not fastest but most reliable
Discussion in 'nVidia Flavor' started by eddie500, Nov 19, 2017.
  1. eddie500
    eddie500 Gawd
    925
    Jan 23, 2003
    Was thinking of buying a 1080ti, but overwhelmed with how many versions there are.
    I was leaning towards an EVGA because I wasn't happy with ASUS warranty on my 970 Asus strix. But then I read where EVGA only has 2 slot cards and they don't cool well, and you need a 3 slot card.
    Does anyone know what is the best card to get right now for warranty, cooling, reliability?
    Thanks.
  2. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,668
    Jan 1, 2008
    EVGA
    If you don’t want ASUS or EVGA, you are going to find problems with every brand you look at :)
    Phattio and williacm like this.
  3. UnknownSouljer
    UnknownSouljer [H]ardness Supreme
    5,711
    Sep 24, 2001
    What is your concern? Are you needing to use this card for 20 years 24/7 in a non temperature controlled environment?
    The warranty service will probably be a much more useful tool than trying to find a card with the best cooling.
    EDIT: and with that, probably EVGA.
  4. eddie500
    eddie500 Gawd
    925
    Jan 23, 2003
    I just had so many issues with my 970GTX, not sure if it was cooling related or what. I just didn't want to deal with any of that. I heard that you really need a 3 card slot for effective cooling, and EVGA 2 card slot was not enough.
    I also was not happy with ASUS warranty, especially how long it took to send back and receive a card.
  5. Ocellaris
    18,668
    Jan 1, 2008
    You don’t “need” a three slot cooler for a 1080ti, otherwise people would have cards failing all over the place.
    Armenius likes this.
  6. Decibel
    Decibel 2[H]4U
    3,806
    Nov 10, 2000
    If you're in North America, EVGA.
    sonsonate likes this.
  7. Archaea
    Archaea [H]ardForum Junkie
    8,709
    Oct 19, 2004
    Evga Black SC
    or SC2
    Are amazing cards. The ICX cooler is only 2 fans and it works fantastic. It’s about 25*c cooler than a reference blower at the same speeds. The EVGA ICX based coolers are my favorite of the 9, 1080ti cards I have. (Mining)
  8. manilaboy1vic
    manilaboy1vic [H]Lite
    72
    Jan 4, 2014
    I have a gigabyte 1080Ti, been running great for months now....
    i did have to RMA some cards in the past tho.. MSI & XFX
  9. Zepher
    Zepher [H]ipster Replacement
    16,570
    Sep 29, 2001
    I buy EVGA cards since they have great warranty service if you need to RMA a card. I've only had to RMA 3 cards over the past 8 or so years,
    First one was an AGP 7800GS, second was a GTX260, and then a used GTX980 SC that I bought earlier this year on craigslist, failed a week after I bought it.
    I am replacing the 980 SLI setup later today with an EVGA GTX1080ti FTW3 card when it arrives this afternoon.
  10. eclypse
    eclypse 2[H]4U
    2,834
    Dec 7, 2003
    If you want a cool card and don't want to go water cooling grab a evga ftw3. The elite model has memory rates for 12ghz over the normal 11ghz model. Mine ran at 51/53c 100% fans that are not loud. Room temp at 72c.
    Went with water cooling anyways cause the new case I bought was for a water cooled system and grabbed a ek ftw3 block and now she runs at 22c idle and 31-33c load durring benches!!
  11. Mister E
    Mister E ?
    2,616
    Sep 14, 2004
    Another happy evga customer here. Runs great, looks great and does the job. I’ve never had to rma an evga card and I’ve owned 6 of them over the years.
  12. _l_
    _l_ I Am A Cock
    1,178
    Nov 27, 2016
    EVGA
    free 24/7 tech phone support (average time on hold < 5 minutes) and EVGA uses the best available components, best build quality, etc
    dvsman likes this.
  13. eclypse
    eclypse 2[H]4U
    2,834
    Dec 7, 2003
    Yup will answer the phone in a min on sunday!! Yup.. and an American guy answered!! Can you imagine that??
  14. Archaea
    8,709
    Oct 19, 2004
    It’s the little things and EVGA delivers. The retail box for an EVGA cards makes you feel like you’ve just been awarded a gift of honor. Lots of foam for cushioning, stickers, a full size EVGA poster, adapters, Black rubber Evga labeled slot guards. — the works. It feels like you are opening a package with precious cargo that the manufacturer is proud of and thus so should you be. Contrast that to many cards these days have moved to minimalist packing with nothing included in the box — so much so that my Powercolor cards didn’t even ship with protective foam — just brown ordinary cardboard protecting the video card inside the retail box. Lame.
  15. Supercharged_Z06
    Supercharged_Z06 2[H]4U
    2,361
    Nov 13, 2006
    Also a vote for EVGA. Solid customer support and good cards. I would have gone EVGA on my last GPU purchase as well, only Nvidia was the only vendor to sell them.
  16. Bawjaws
    Bawjaws Limp Gawd
    275
    Feb 20, 2017
    EVGA warranty is also transferable, which is a bonus in terms of resale.
  17. kasakka
    kasakka Gawd
    966
    Aug 25, 2008
    Yup seems like a no-brainer considering they seem to have the best warranty options. In Europe all cards have two year warranty and you deal with the shop rather than the OEM so it matters much less and then I would look into ASUS and MSI just because their air cooled solutions usually make less noise than the competition.
  18. IdiotInCharge
    IdiotInCharge Not the Idiot YOU are Looking for
    7,898
    Jun 13, 2003
    One thing to consider: the best/easiest way to get a great cooled 1080Ti is to get the watercooled version that Corsair made for Evga and MSI with the radiator preattached.
    Top overclocks while silent under load and low load temps to boot; the MSI version seems to go on sale for US$709 (and it's made/customized by Corsair).
  19. kasakka
    kasakka Gawd
    966
    Aug 25, 2008
    If you have space to fit the radiator. I have a similar setup on my MSI 980 Ti and I love it. These top end cards should definitely have AIO coolers because it makes such a huge difference in noise.
  20. Probleminfected
    Probleminfected [H]ard|Gawd
    1,333
    Dec 20, 2013
    Most reliable card would probably be a EVGA founders edition. They are a little loud, but made to last for a very long time. And with EVGA you get their warranty and rma team, both are great.
    sonyman likes this.
  21. Dayaks
    Dayaks [H]ardness Supreme
    6,369
    Feb 22, 2012
    I had 3 of 3 of my EVGA 1080ti SC2's pumps die within two months. :\
  22. IdiotInCharge
    7,898
    Jun 13, 2003
    I remember you posting about that- did you ever get any feedback?
    I wonder if there wasn't a common denominator other than the product itself, like a power issue in your system. I'll admit that that's reaching, but your case does seem to be special (and I'm keeping a close eye on mine!).
  23. eclypse
    eclypse 2[H]4U
    2,834
    Dec 7, 2003
    I've read about alot of people complaining about dead pumps on hybrid evga cards the past month on evga forums.. No doubt a serious bad batch going around.
  24. Dayaks
    6,369
    Feb 22, 2012
    I never sent them in because I didn't want to pay $70-100 in shipping. I just put a 655 pump into the loop. (1/4" fittings and splicing). Eventually added my 9x140mm rad. I did everything they asked though... and my rads were higher than the pump to begin with, never over 60C, even took the cards out and shook them around a bit like they asked.
    I did get confirmation because others had the exact same problem (not surprising). Running under 60C then one day - bam 91C and no or very low pump flow. A failure rate like that... I hope it was only a small batch.
    The EVGA guys were very nice. Just did not care for the shipping, time, and I had my custom loop stuff laying around. :)
    Kwaz, Mav451 and IdiotInCharge like this.
  25. sonyman
    sonyman Gawd
    849
    Apr 23, 2003
    The reference cooler is never a bad option and is the one best suited for the largest possible configuration space due to the inherent trade-offs of a blower. I'm not a fan of EVGA's own air coolers (although I've never owned a card so-equipped) but their warranty service is top-notch, speaking from experience. Regardless, at this point, the GTX 1080 TI has been out long enough that I expect there is no "bad" option, so I suggest putting after-sales support at the top of your list and then buying from whomever offers the best product from among Nvidia's authorized board partners.
  26. Armenius
    Armenius [H]ardForum Junkie
    15,449
    Jan 28, 2014
    MSi Sea Hawk X
  27. eclypse
    eclypse 2[H]4U
    2,834
    Dec 7, 2003
    I believe corsair also makes evga's cooler as well. So they might be sharing the same bad batch of pumps.
  28. IdiotInCharge
    7,898
    Jun 13, 2003
    Yup, the EVGA and MSI closed-loop versions are actually Corsair (and the Corsair branding is present on both).
    Mine's still going strong, FWIW, I'll count myself lucky!
    [and if you get a good one, they are very nice]
  29. KickAssCop
    KickAssCop [H]ardness Supreme
    6,512
    Mar 19, 2003
    ASUS STRIX. No pump nonsense. Quiet card. Runs 69 C max temps when my ambient is around 26 C. Plays games like a champ. Can't recommend it enough.
  30. legcramp
    legcramp [H]ardForum Junkie
    10,722
    Aug 16, 2004
    EVGA, ASUS isn't in the same ballpark.
  31. KickAssCop
    6,512
    Mar 19, 2003
    ASUS, EVGA isn't in the same ballpark. At least in my experience EVGA cards always clocked worse for me.
  32. ng4ever
    ng4ever Flaccid 4Evar
    990
    Feb 18, 2016
    Help guys.
    EVGA video cards only have one HDMI port is that enough for the future ?
    What advantage would it bring to have more than 1 HDMI port?
  33. eclypse
    eclypse 2[H]4U
    2,834
    Dec 7, 2003
    In vr it makes a difference being able to plug the headset in and also a 4k monitor if that also uses HDMI.
    Most pc monitors now a days use display port.
    Either way one can easily buy adapters to change either port to what you need.
    Currently I have the rift vr connected to the main HDMI port and a display port to 4k ultra HDMI adapter to my Samsung 40" 4k tv for my main desktop display.
    ng4ever likes this.
  34. RazorWind
    RazorWind 2[H]4U
    3,041
    Feb 11, 2001
    EVGA theoretically has the best warranty, but they had a spate of reliability issues last year with their higher end 10 series cards related to defective surface mount components, so it's really just going to be up to luck. I would actually argue that the most reliable card is likely to be the Founder's Edition, on the grounds that it has only one fan. In 20 years of being a PC enthusiast, fan failures are the only thing I've ever actually had go wrong with a graphics card that wasn't DOA.
    If your definition of reliability includes "reliably get a warranty replacement" go EVGA. If it's uptime, Founder's Edition. Otherwise, like I posted in another thread today, buy based on the features you want.
    VR would be the most obvious advantage. All the current headsets connect via HDMI, meaning that if your monitor is a TV (seems like this would be common with VR setups), you need an adapter of some sort.
  35. eclypse
    eclypse 2[H]4U
    2,834
    Dec 7, 2003
    Yes a Display port to HDMI adapter.. if it's to a 4k screen grab one rated for ultra 4k.
  36. tangoseal
    tangoseal [H]ardness Supreme
    6,545
    Dec 18, 2010
    I have twin Asus Poseidon 1080ti and a generic nVidia branded 1070..
    I highly recommend ASUS or EVGA.
    My Asus cards are very nice and well built and solidly represented.
    1080ti are beast mode...
    I also run a 1070 and its like weak as shit... after going from dual 1080ti's to my other box with a 1070 I feel like im on an Intel IGP. Not kidding.
    eclypse likes this.
  37. oldmanbal
    oldmanbal [H]ard|Gawd
    1,922
    Aug 27, 2010
    Beware evga fans they are loud as shit. I don't understand why so many ppl are obsessed with them.
  38. kirbyrj
    kirbyrj Why oh why didn't I take the BLUE pill?
    23,471
    Feb 1, 2005
    Because of the warranty.
  39. oldmanbal
    1,922
    Aug 27, 2010
    Yeah I knew the answer I was just trying to be dramatic. I would never buy another EVGA card personally. I see so much feedback from people that wax poetic about their sc or ftw cards, who have literally never owned a card with a quiet fan. Makes me feel like i'm back in 2006 with a massive cfm beast on my cpu.
    kirbyrj likes this.
  40. eclypse
    eclypse 2[H]4U
    2,834
    Dec 7, 2003
    Best is to prob go with a founders edition from evga.. thst way evga didn't design it but you still get the evga warranty.. and that also means you can slap a water block on it or aio and also got good warranty.
