Is remote desktop connection only for computers within an internal network?
J32P2006
Is Remote Desktop Connection only for connecting computers within an internal network?
For instance, Say I have two computers, each on it's own modem hooked to roadrunner. There within a mile from eachother, can I remote desktop from one to the other?
Also, if you can, then how do i set it up.
I see the tab Remote under My Computer Properties which you have to check both those check boxes, but what else do you have to do?
And how do you send an invite, or put in the person who can remote connect ?
Thanks for your time,
J32P2006
Kreator
Provided that it sounds like both PC's are running WinXP - you need the following:
-The external (public) ip address of each machine (http://www.network-tools.com will show you this when you first connect)
-Identify if you are using a router/switch with an internal network. IF so:
-Find the IP address on your internal network of those specific PC's
-Using the configuration page/software for either your router/switch, forward TCP port 3389 (default for RDP) to the internal IP's you found
-Then RDP into the external (public) IP address you first received and you should have connectivity.
Hope this helps
Kreator
no problem tell me if you run into trouble i frequent this forum looking for advice from those much more intelligent than i am
Malk-a-mite
One of those boxes is for Remote Assistance, the other for Remote Desktop. They have different relationships to your computer and the type of access they offer.
Remote assistance walk thru:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/remoteassist/intro.mspx
Remote Desktop walkthru:
http://www.microsoft.com/windowsxp/using/mobility/getstarted/remoteintro.mspx
dbwillis
If you dont know the Internet IP's of the computers, you can always use one of the free DNS services (ie DynDNS) and then Remote Desktop to that address (www.webaddress.com)
feigned
no-ip.org is another. Highly recommended.
Good thing I saw this thread...forgot to reinstall the service to keep my no-ip address.
