Is New Ryzen Going to Have Entry Level?
Discussion in 'AMD Processors' started by MajorYikes, Jun 3, 2019.
  1. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    I see a bunch of stuff $300+ in the announcements but will they have anything sub $300?
    I’ve never been one to buy top of the line, I can’t justify it as I don’t use all the power. Is there going to be a part I can afford?
  2. Snowdog
    Snowdog [H]ardForum Junkie
    9,243
    Apr 22, 2006
    Straight from AMD. line-up (so far) and Price list, including Ryzen 5 3600 for $199 USD:
    https://www.amd.com/en/press-releas...ion-leadership-products-computex-2019-keynote
    Code:
    3rd Gen AMD Ryzen Desktop Processor Line-up and Availability
    Model                    Cores/Threads             TDP (Watts)         Boost/Base Freq.              SEP (USD)
    Ryzen™ 5 3600            6/12                      65W                 4.2/3.6                           $199
    Eventually there will probably be parts close to $99 (4 core), but AMD will likely be clearing Ryzen 2000 series parts for a long time and want to maximize ASP on 7nm Ryzen 3000 parts, so they are in no hurry to introduce those.
  3. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    Ah okay. I got my info from an unnamed podcast in which they didn’t mention anything of the sort.
    Good to see for a guy like me. Someone can close this if need be .
  4. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,460
    Sep 13, 2008
    wouldn't be surprised if they show off the 3600x and maybe announce a 3500x at e3 since those 4/8 and 6/12 chips tended to be much more popular with most gamers. that being said i wonder what the TDP range will be on the 4/8 chips.
  5. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    Also really curious about the 6/12 TDP...would be awesome to see how it will stack up to my 9400F considering power draw and the lack of HT on my 9400.
  6. TheRookie
    TheRookie Limp Gawd
    156
    May 21, 2019
    As far as I am aware, the only new Ryzen 3 coming (excluding OEM products) is the Ryzen 3 3200G, which is basically a higher clocked Ryzen 3 2200G.
  7. somebrains
    somebrains Gawd
    685
    Nov 10, 2013
    None of the Zen+ line works as a starter cpu for the OP?
    If you don't use much there are plenty of used 1300's and 1600's out there for less than the cost of a movie date.
    dvsman likes this.
  8. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    I just bought a 1200 off of you haha
    KazeoHin and somebrains like this.
  9. somebrains
    somebrains Gawd
    685
    Nov 10, 2013
    I was thinking about that when I was reading this thread.
    Trying to imagine x570 release day buyers at $500+ running an older cpu that’s under $100 waiting to go all in on a 12+ core the next pay check.
  10. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    That 1200 is for a side project not my main rig lol. I MAY just spring and get a new Ruzennif they live up to the hype.
  11. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    Do you have your eyes on one? Like I stated before I never have a real reason to but I always like to have something new.
  12. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    6,315
    Feb 7, 2003
    Ryzen (3) 3200G and Ryzen (5) 3400G should be coming out soon.
    TheRookie likes this.
  13. Snowdog
    9,243
    Apr 22, 2006
    Yeah, but these are NOT 7nm Zen 2 parts, just Raven Ridge with a mild process refresh 12nm (AKAK 14nm+) and Zen+.
    Really these match Ryzen 2000 Series parts without APU, not 3000 series without APU.
  14. TheRookie
    TheRookie Limp Gawd
    156
    May 21, 2019
    Well, the is no reason why budget parts need to be on AMD's latest and greatest architecture.
  15. Snowdog
    9,243
    Apr 22, 2006
    If someone states that they want "new" Ryzen, they probably mean the new Zen 2 architecture. I am just making it clear that AMDs naming can be confusing on this issue.
    drescherjm and MajorYikes like this.
  16. ir0nw0lf
    6,315
    Feb 7, 2003
    Simply answering per the OP. As you mentioned ^^ they likely meant 3xxx non-G. :D
  17. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,352
    Jun 13, 2003
    Plenty of reasons that their 'budget' parts could stand to be on their latest architecture. Right tool for the job and all.
  18. TheRookie
    TheRookie Limp Gawd
    156
    May 21, 2019
    ...such as?
  19. IdiotInCharge
    11,352
    Jun 13, 2003
    Microservers (AMD sells them as 'Ryzen Pro'), NUC-sized devices, mobile.
    It should be blindingly obvious how useful having a competitive APU could be.
  20. Nightfire
    Nightfire [H]ard|Gawd
    1,709
    Sep 7, 2017
    Obviously there will be lower priced Zen 3 parts. If you are looking for a budget build, new 8 cores can be found for $150 and 6 cores can be found for $100 so there is no real reason to hold off (other than a few watts) as they will most likely be a better bang for the buck than the new lower end zen 3 parts, at least for a while.
    IdiotInCharge likes this.
  21. KazeoHin
    KazeoHin [H]ardness Supreme
    7,843
    Sep 7, 2011
    Being an enthusiast is rough, man.
    dragonstongue and Boil like this.
  22. bobzdar
    bobzdar [H]ard|Gawd
    1,632
    Jun 6, 2003
    What do you deem competitive? They already have the fastest apu by a pretty long shot - as in double the performance of their nearest (only?) competitor, so they're pushing as much 7nm silicon as they can at the server and high core count desktop space. When Intel releases a competitive igp (this fall?) I'd expect a 7nm response fairly quickly, but they need to pump out as many epycs as they can to satisfy demand.
  23. dragonstongue
    dragonstongue 2[H]4U
    3,127
    Nov 18, 2008
    depends on their yield as well as how many "cores" can be bin tested as well as the chiplet (I/O chip) maybe there is no 4/8 "standard" as there was with 2xxx and 1xxx Ryzen, I suppose totally depends on how good their yields are and how many they can "save" from the trash bin.
    I imagine likely far more 4/8 then 6/12 will make the "de-bin" to lesser parts, then again, only AMD really knows currently their future 3xxx Zen 2 product stack will shape up to be.
    I am sure there will be "something" though at the same time, this is not Intel it is AMD, not need 200 chips from one generation missing one feature or not having the same "abilities" instead is more or less a nice clean line from "this is a budget chip" to "you must really have money to burn or serious work to do with all them core(s)"
  24. jlbenedict
    jlbenedict [H]ard|Gawd
    1,325
    May 22, 2005
    So a R5 3600 is only 300 mhz higher in boost (200 base) clock.. but leaked benchmarks show it 25% improvement over the R5 2600..
    (compared to early pre-launch rumor's leaks -
    Ryzen 5 3600 8/16 Base 3.6GHz Boost 4.4GHz 65W)
  25. TheRookie
    TheRookie Limp Gawd
    156
    May 21, 2019
    ...and why do, for example, NUC needs to be on Zen 2?
    At least, with laptops, you can make a case that 7nm helps with reduced heat/power consumption
  26. Nobu
    Nobu 2[H]4U
    3,193
    Jun 7, 2007
    Well...
    3.6GHz * 1.15 (15% ipc improvement) = 4.14GHz (comparible zen+ spec)
    4.14 / 3.4 = 1.217 (or approx 22% performance advantage)
    That's not accounting for boost or xfr if present.
    RAutrey likes this.
  27. IdiotInCharge
    11,352
    Jun 13, 2003
    Competitive on the CPU side. The graphics side is less important, really, it just needs to be there.
    The challenge is that the niche where their APUs exist is extremely small. APU graphics won't be competitive with discrete parts unless they can significantly increase bandwidth, and they need to do that while keeping main memory latency low. Intel's Iris solution is one method that seems to work pretty well, and their collaboration with AMD to put an AMD GPU with HBM on the same module works pretty well too.
    Just hooking it up to main memory they have a performance cap.
    Why not? Bring them up to near Skylake single-core performance with a competent IGP in a tiny package?
    That would be exciting. I wish they'd announced something along those lines that might compete with Sunny Cove. As it stands, ultrabooks belong to Intel.
  28. Orddie
    Orddie 2[H]4U
    2,508
    Dec 20, 2010
    its AMD. everything is entry level and intel prices.
  29. TheFlayedMan
    TheFlayedMan Limp Gawd
    392
    May 29, 2015
    I hope there is some overclocking headroom on the 3600. If they could easily clock to 4.7Ghz or more AMD will have something that will fly off the shelves I think.
  30. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    Remember the days when a +\-25% OC wasn’t far fetched?
    pendragon1 likes this.
  31. TheFlayedMan
    392
    May 29, 2015
    Yes a return to those days would be nice
  32. IdiotInCharge
    11,352
    Jun 13, 2003
    300A Master Race reporting
    RAutrey, Nightfire and MajorYikes like this.
  33. TheRookie
    TheRookie Limp Gawd
    156
    May 21, 2019
    There you go:
  34. MajorYikes
    MajorYikes n00b
    57
    Mar 22, 2019
    Yeeesh I’m reading leaks saying $149 for the 3400G? Wonder how true this is.
    At $149, I’ll be in. I’ll either sell my current rig or just build a second one. I haven’t had an AMD rig in years...looking like it’s probably going to happen.
    EDIT: TheRookie, I just saw your post. Shoot the 6C/12T at $199 looks pretty damn good to me...
    TheRookie and Algrim like this.
  35. IdiotInCharge
    11,352
    Jun 13, 2003
    Shouldn't be an issue given that the APUs are stuck on Zen+ and not getting an upgrade like the rest of the line. Recommend stretching to the R5 3600 at the least; those boost clocks on the APUs are essentially the ceiling, and they can still be finicky with RAM (which you'll want to maximize with an APU).
    Snowdog likes this.
