Is my laptop hosed?
Discussion in 'Mobile Computing' started by peppergomez, Jul 28, 2018.
  1. peppergomez
    peppergomez Gawd
    656
    Sep 15, 2011
    I cleaned the keyboard off last night with one of those cleaner pads that is very slightly moist (not wet enough to have liquid dripping off of it, though). Some liquid must have dripped into the circuits because now many of the keys are typing gibberish, or multiple characters.
    I don't know what I can do about that, and am concerned that I might have fried my system.
  2. Loose Nut
    Loose Nut Limp Gawd
    352
    Oct 21, 2009
    it will dry, or use a can of compressed air. works wonders.
    auntjemima likes this.
  3. peppergomez
    peppergomez Gawd
    656
    Sep 15, 2011
    thx, do I need to open the case up when using the compressed air?
  4. thecold
    thecold Limp Gawd
    238
    Nov 12, 2017
    What's the model of laptop?
  5. peppergomez
    peppergomez Gawd
    656
    Sep 15, 2011
    MSI Gaming G Series, Model MS-1763
  6. pendragon1
    pendragon1 [H]ardForum Junkie
    10,735
    Oct 7, 2000
    should e dry by now. is it working?
  7. drescherjm
    drescherjm [H]ardForum Junkie
    14,152
    Nov 19, 2008
    Be careful if you attempt to remove the keyboard. I killed a similar MSI laptop doing a cleanup from the mess a 20 once cup of coffee made. I think the damage was done by putting the monitor cable in. I did not notice that it was on an angle (shorting the pins)..
  8. peppergomez
    peppergomez Gawd
    656
    Sep 15, 2011
    it's still wacky....certain keys don't respond and certain keys get randomly triggered to be activated endlessly after it's been on for a few minutes.
  9. pendragon1
    10,735
    Oct 7, 2000
    take it apart and hit the contacts with contact cleaner, clean all the pads, let it dry, reassemble and hope it works or get a new keyboard for ~$60 on ebay.
  10. peppergomez
    peppergomez Gawd
    656
    Sep 15, 2011
    how hard is that repair to do? I have to order a new one since a place I took it to dehyrdated it and the keyboard is still on the fritz. they quoted me $180 in a text for the replacement and repair. I'm not an experienced computer tinkerer and the poster above me mentioned the risk. if it's not too tricky, I might give it a shot to save $100, but if it is, I'd sooner just pay them. thanks
  11. pendragon1
    10,735
    Oct 7, 2000
    not hard. I think on that unit there is a plastic trim piece at the top of the k/b, pop that off, undo 5 screws, unhook a ribbon and its out
  12. peppergomez
    peppergomez Gawd
    656
    Sep 15, 2011
  13. peppergomez
    peppergomez Gawd
    656
    Sep 15, 2011
    Thanks everyone. I was able to do the keyboard replacement successfully. That saved me almost $150 in repair costs. Much appreciated!
    pendragon1 likes this.
  14. pendragon1
    10,735
    Oct 7, 2000
    no prob! glad you got it sorted.
