Is my 9900K not stable? crash in battlefield 5 without error
Discussion in 'General Hardware' started by mgty23, Jun 5, 2019.
  1. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    Hi my pc.
    9900K stock turbo 4.7 . All auto settings in bios. VOLTAGE on AUTO.
    Noctua NH-D15 .Temps 60-70C
    2x16 GB DDR4 GSKILL 3000 XMP
    Corsair 850RmX
    Aorus 2080 Ti Xtreme , no oc,stock.
    All stress tests passing fine. I dont have any crashes in game.
    But few days ago, i go out to work, and i left running game BF 5. When i back,game was running 13 hours,and in 14 hour ( it was 3 am ) it crashed to desktop. Event viewer nothing said. No error message,no display crash. Just exit to desktop.
    Game just was on 14 hours,and after moment it go to desktop withour error message. I dont touch anything,game was in campaign mode,when character is standing on the same place.
    Now i am testing again and see if i can reproduce, but i cant. I am currently on 80 hour and not crashed again.
    Is this reason to worry?My drivers are the newest.
    Maybe XMP issue or auto voltage? Or issue with game?
  2. Meeho
    Meeho [H]ardness Supreme
    4,303
    Aug 16, 2010
    The cat walked on the KB.
  3. spine
    spine 2[H]4U
    2,541
    Feb 4, 2003
    Windows 10 right?
  4. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
  5. Spartacus09
    Spartacus09 Gawd
    982
    Apr 21, 2018
    What motherboard? Mine had issues at stock too i had to manually change the voltage.
    That was alot more consistent crashing though.
  6. spine
    spine 2[H]4U
    2,541
    Feb 4, 2003
    Most likely it's just Windows 10 updating some shit and causing the crash.
    If it were hardware, it would be alot more frequent and re-produceable to a certain extent.
  7. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    Version 10.5.40.26928. What is date of that version? Some sites tell 2 june 2019 some its3 June and some even 2017 year.
    Also my Origin is 10.5.40.26928 actually but files date are 31.05 in folder Origin. Any ideas?
    I investigating some thing. I had one weird exit from BF 5 in 2 June near 3 a.m. Maybe somehow it was update but i was not logged out.
    So how i can check when that 10.5.40.26928 was installed / or updated?If anyhow i can . Also is this possible that origin was updated to that version without logging out?
    And finally what is release date for 10.5.40.26928. Some sites said 2/3 june 2019 ,may 2019 and even 2017 year .
    And yeah it happened once not again
  8. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    Here is log:
    0:016> !analyze -v
    * Exception Analysis *
    *** WARNING: Unable to verify timestamp for dbdata.dll
    KEY_VALUES_STRING: 1
    Key : AV.Dereference
    Value: NullClassPtr
    Key : AV.Fault
    Value: Read
    Key : Analysis.CPU.Sec
    Value: 5
    Key : Analysis.Elapsed.Sec
    Value: 131
    Key : Analysis.Memory.CommitPeak.Mb
    Value: 204
    Key : Timeline.Process.Start.DeltaSec
    Value: 49516
    PROCESSES_ANALYSIS: 1
    SERVICE_ANALYSIS: 1
    STACKHASH_ANALYSIS: 1
    TIMELINE_ANALYSIS: 1
    Timeline: !analyze.Start
    Time: 2019-06-09T17:06:57.933Z
    Diff: 663944933 mSec
    Timeline: Dump.Current
    Time: 2019-06-02T00:41:13.0Z
    Diff: 0 mSec
    Timeline: Process.Start
    Time: 2019-06-01T10:55:57.0Z
    Diff: 49516000 mSec
    DUMP_CLASS: 2
    DUMP_QUALIFIER: 400
    MODLIST_WITH_TSCHKSUM_HASH: ecae460c3b09697da4b7d808edddb7af9cabb419
    MODLIST_SHA1_HASH: b436539aa6f3750791d04ac1da7f12b3daf8b6e7
    COMMENT: Frostbite MiniDump. Address: 0000000145DE184D (In Windbg type: .ecxr)
    [EOF]
    NTGLOBALFLAG: 0
    PROCESS_BAM_CURRENT_THROTTLED: 0
    PROCESS_BAM_PREVIOUS_THROTTLED: 0
    DUMP_FLAGS: a2
    DUMP_TYPE: 11
    CONTEXT: (.ecxr)
    rax=00000000abd23ce0 rbx=00000000accc5820 rcx=0000000000000000
    rdx=0000000000000000 rsi=000000000055fd80 rdi=0000000033fe2710
    rip=0000000145de184d rsp=0000000033fe1a00 rbp=0000000033fe1be0
    r8=0000000000000006 r9=0000000000000001 r10=0000000000000006
    r11=0000000033fe1a68 r12=0000000000000000 r13=0000000000000000
    r14=ffffffffffffffff r15=0000000000000000
    iopl=0 nv up ei pl zr na po nc
    cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010246
    bfv+0x5de184d:
    00000001`45de184d 488b5238 mov rdx,qword ptr [rdx+38h] ds:00000000`00000038=????????????????
    Resetting default scope
    FAULTING_IP:
    bfv+5de184d
    EXCEPTION_RECORD: (.exr -1)
    ExceptionAddress: 0000000145de184d (bfv+0x0000000005de184d)
    ExceptionCode: c0000005 (Access violation)
    ExceptionFlags: 00000000
    NumberParameters: 2
    Parameter[0]: 0000000000000000
    Parameter[1]: 0000000000000038
    Attempt to read from address 0000000000000038
    DEFAULT_BUCKET_ID: NULL_CLASS_PTR_READ
    PROCESS_NAME: bfv.exe
    FOLLOWUP_IP:
    bfv+5de184d
    READ_ADDRESS: 0000000000000038
    ERROR_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
    EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
    EXCEPTION_CODE_STR: c0000005
    EXCEPTION_PARAMETER1: 0000000000000000
    EXCEPTION_PARAMETER2: 0000000000000038
    WATSON_BKT_PROCSTAMP: 5047ff9c
    WATSON_BKT_MODULE: bfv.exe
    WATSON_BKT_MODSTAMP: 5cdbc3d7
    WATSON_BKT_MODOFFSET: 5de184d
    WATSON_BKT_MODVER: 1.0.72.44435
    BUILD_VERSION_STRING: 17763.1.amd64fre.rs5_release.180914-1434
    ANALYSIS_SESSION_HOST: DESKTOP-RVP2EUM
    ANALYSIS_SESSION_TIME: 06-09-2019 19:06:57.0933
    ANALYSIS_VERSION: 10.0.18869.1002 amd64fre
    THREAD_ATTRIBUTES:
    OS_LOCALE: PLK
    BUGCHECK_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ
    PRIMARY_PROBLEM_CLASS: APPLICATION_FAULT
    PROBLEM_CLASSES:
    Type: [@ACCESS_VIOLATION]
    Class: Addendum
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Type: [INVALID_POINTER_READ]
    Class: Primary
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Type: [NULL_CLASS_PTR_DEREFERENCE]
    Class: Primary
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Type: [NULL_CLASS_PTR_READ]
    Class: Primary
    Scope: DEFAULT_BUCKET_ID (Failure Bucket ID prefix)
    BUCKET_ID
    Data: Omit
    PID: [0x28cc]
    TID: [0xb30]
    Frame: [0] : bfv
    IP_ON_HEAP: 0000000000400000
    The fault address in not in any loaded module, please check your build's rebase
    log at <releasedir>\bin\build_logs\timebuild\ntrebase.log for module which may
    contain the address if it were loaded.
    FRAME_ONE_INVALID: 1
    LAST_CONTROL_TRANSFER: from 0000000000400000 to 0000000145de184d
    STACK_TEXT:
    00000000`33fe1a00 00000000`00400000 : 00000002`145b8ca0 00000000`0055fd80 00000002`188990d0 00000000`00000000 : bfv+0x5de184d
    00000000`33fe1a08 00000002`145b8ca0 : 00000000`0055fd80 00000002`188990d0 00000000`00000000 00000000`00000000 : 0x400000
    00000000`33fe1a10 00000000`0055fd80 : 00000002`188990d0 00000000`00000000 00000000`00000000 00000000`33fe2710 : 0x00000002`145b8ca0
    00000000`33fe1a18 00000002`188990d0 : 00000000`00000000 00000000`00000000 00000000`33fe2710 00000001`45e11736 : 0x55fd80
    00000000`33fe1a20 00000000`00000000 : 00000000`00000000 00000000`33fe2710 00000001`45e11736 00000000`00000006 : 0x00000002`188990d0
    THREAD_SHA1_HASH_MOD_FUNC: f86e706f3881ff99410f64522468510881cb97a0
    THREAD_SHA1_HASH_MOD_FUNC_OFFSET: fc53bee7bd5eee7c273e1f674a644f5504b35eba
    THREAD_SHA1_HASH_MOD: f86e706f3881ff99410f64522468510881cb97a0
    FAULT_INSTR_CODE: 38528b48
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: bfv+5de184d
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: bfv
    IMAGE_NAME: bfv.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 5cdbc3d7
    STACK_COMMAND: ~16s ; .ecxr ; kb
    FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_c0000005_bfv.exe!Unknown
    BUCKET_ID: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ_bfv+5de184d
    FAILURE_EXCEPTION_CODE: c0000005
    FAILURE_IMAGE_NAME: bfv.exe
    BUCKET_ID_IMAGE_STR: bfv.exe
    FAILURE_MODULE_NAME: bfv
    BUCKET_ID_MODULE_STR: bfv
    FAILURE_FUNCTION_NAME: Unknown
    BUCKET_ID_FUNCTION_STR: Unknown
    BUCKET_ID_OFFSET: 5de184d
    BUCKET_ID_MODTIMEDATESTAMP: 5cdbc3d7
    BUCKET_ID_MODCHECKSUM: ef4e508
    BUCKET_ID_MODVER_STR: 1.0.72.44435
    BUCKET_ID_PREFIX_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ_
    FAILURE_PROBLEM_CLASS: APPLICATION_FAULT
    FAILURE_SYMBOL_NAME: bfv.exe!Unknown
    TARGET_TIME: 2019-06-02T00:41:13.000Z
    OSBUILD: 17763
    OSSERVICEPACK: 475
    SERVICEPACK_NUMBER: 0
    OS_REVISION: 0
    SUITE_MASK: 256
    PRODUCT_TYPE: 1
    OSPLATFORM_TYPE: x64
    OSNAME: Windows 10
    OSEDITION: Windows 10 WinNt SingleUserTS
    USER_LCID: 0
    OSBUILD_TIMESTAMP: 1989-09-10 08:58:46
    BUILDDATESTAMP_STR: 180914-1434
    BUILDLAB_STR: rs5_release
    BUILDOSVER_STR: 10.0.17763.1.amd64fre.rs5_release.180914-1434
    ANALYSIS_SESSION_ELAPSED_TIME: 2033c
    ANALYSIS_SOURCE: UM
    FAILURE_ID_HASH_STRING: um:null_class_ptr_read_c0000005_bfv.exe!unknown
    FAILURE_ID_HASH: {f476daa4-68b6-2895-45dc-838c7fe6b3de}
    Followup: MachineOwner
    0:016> !analyze -v
    Value: NullClassPtr
    Key : AV.Fault
    Value: Read
    Value: 1
    Value: 1
    Value: 211
    Value: 49516
    SERVICE_ANALYSIS: 1
    Time: 2019-06-09T17:09:09.843Z
    Diff: 664076843 mSec
    Diff: 0 mSec
    Diff: 49516000 mSec
    DUMP_CLASS: 2
    DUMP_QUALIFIER: 400
    [EOF]
    NTGLOBALFLAG: 0
    DUMP_FLAGS: a2
    DUMP_TYPE: 11
    CONTEXT: (.ecxr)
    bfv+0x5de184d:
    FAULTING_IP:
    bfv+5de184d
    NumberParameters: 2
    FOLLOWUP_IP:
    bfv+5de184d
    ANALYSIS_SESSION_TIME: 06-09-2019 19:09:09.0843
    THREAD_ATTRIBUTES:
    OS_LOCALE: PLK
    PROBLEM_CLASSES:
    Class: Addendum
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Class: Primary
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Class: Primary
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Class: Primary
    BUCKET_ID
    Data: Omit
    PID: [0x28cc]
    TID: [0xb30]
    Frame: [0] : bfv
    STACK_TEXT:
    MODULE_NAME: bfv
    IMAGE_NAME: bfv.exe
    OSBUILD: 17763
    OSSERVICEPACK: 475
    OS_REVISION: 0
    SUITE_MASK: 256
    PRODUCT_TYPE: 1
    OSNAME: Windows 10
    USER_LCID: 0
    ANALYSIS_SESSION_ELAPSED_TIME: 76d
    ANALYSIS_SOURCE: UM
    0:016> !analyze -v
    Value: NullClassPtr
    Key : AV.Fault
    Value: Read
    Value: 1
    Value: 1
    Value: 219
    Value: 49516
    SERVICE_ANALYSIS: 1
    Time: 2019-06-09T17:09:11.746Z
    Diff: 664078746 mSec
    Diff: 0 mSec
    Diff: 49516000 mSec
    DUMP_CLASS: 2
    DUMP_QUALIFIER: 400
    [EOF]
    NTGLOBALFLAG: 0
    DUMP_FLAGS: a2
    DUMP_TYPE: 11
    CONTEXT: (.ecxr)
    bfv+0x5de184d:
    FAULTING_IP:
    bfv+5de184d
    NumberParameters: 2
    FOLLOWUP_IP:
    bfv+5de184d
    ANALYSIS_SESSION_TIME: 06-09-2019 19:09:11.0746
    THREAD_ATTRIBUTES:
    OS_LOCALE: PLK
    PROBLEM_CLASSES:
    Class: Addendum
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Class: Primary
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Class: Primary
    Scope: BUCKET_ID
    Data: Omit
    PID: [Unspecified]
    TID: [0xb30]
    Frame: [0] : bfv
    Class: Primary
    BUCKET_ID
    Data: Omit
    PID: [0x28cc]
    TID: [0xb30]
    Frame: [0] : bfv
    STACK_TEXT:
    MODULE_NAME: bfv
    IMAGE_NAME: bfv.exe
    OSBUILD: 17763
    OSSERVICEPACK: 475
    OS_REVISION: 0
    SUITE_MASK: 256
    PRODUCT_TYPE: 1
    OSNAME: Windows 10
    USER_LCID: 0
    ANALYSIS_SOURCE: UM
    I tried to reproduce this but i cant. I left game running 3xtimes for 20 hours and nothing again,game is runnin.
  9. SvenBent
    SvenBent 2[H]4U
    2,902
    Sep 13, 2008
    so you had 1 crash in total ?
  10. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    yeah like above after 14 hours in game:)Maybe memtest86 he ? : )
  11. lightsout
    lightsout Gawd
    870
    Mar 15, 2014
    Idk one crash I would ignore personally. It happens. But bfv had this issue recently. I couldn't even play MP for more then five minutes without a crash to desktop.
    It was recommended to roll back my Nvidia driver. Which I did and haven't had the issue.
    Spartacus09 likes this.
  12. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    Ok i run memtest86 for 4 passes :) Just to be sure but i bet there will be not errors :)
  13. Spartacus09
    Spartacus09 Gawd
    982
    Apr 21, 2018
    Wait it was fine for 14 hours of straight gaming and you're concerned about 1 crash :D?
    vegeta535 likes this.
  14. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    just to be sure i ask. Because it never happened before
  15. Spartacus09
    Spartacus09 Gawd
    982
    Apr 21, 2018
    i don't even stress test my system that long, unless it happens frequently I would chock it up to a one time occurrence and not worry to much.
    A crash once a week with Windows might be below average :D.
  16. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
  17. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    Somebody said this to me:"Try to slightly increase your DRAM Voltage (something between +0,015v and +0,050v)! I would bet that the problem is solved after that. I saw a few users before having exact the same problem with the Hero XI and G.Skill Ram as u. Please inform us if it worked!"
  18. TheFlayedMan
    TheFlayedMan Limp Gawd
    331
    May 29, 2015
    All I could tell from the log you posted was it was caused by an unhandled null pointer exception in the game. I would take that as it not being down to your system being unstable and chalk it up to developing games isn't a walk in the park.
  19. mgty23
    mgty23 Limp Gawd
    218
    Mar 16, 2017
    So if happened once and not again its not hardware issue?:)
  20. spine
    spine 2[H]4U
    2,541
    Feb 4, 2003
    No, your system is royally fucked. Best to take it apart and send it all back ASAP. (y)
  21. vegeta535
    vegeta535 2[H]4U
    2,966
    Jul 19, 2013
    Bad idea. He should send it to me instead. 1 crash in hundred hour of test yeah shit is garbage and unstable.
  22. demondrops
    demondrops Limp Gawd
    341
    Jul 7, 2016
    BFV just seems like a very unstable game, atleast it did when i played it. it would react to just power/temp limit no OC and crash. And any OC would fuck it sideways and crash even more to unplayable levels. It would still crash now and then but not often enough to be bothersome. Even tho the OC i used is something that is proven to be stable in all other games i played. And i played like 400 hrs in bf1 with no issues... It could just be that.
  23. Xero717
    Xero717 n00b
    54
    Feb 28, 2011
    Definitely blame it on the game, not your system.
