So it appears to be on the individual as to if its worth using a sound card or onboard. I will just need to hook up rest of my 7.1 speakers and judge for myself. Thanks everyone for pointing out the pros and cons and areas in which to listen to.
While standing in line with my 1/2 price sub this past Boxing Day, I had the opportunity to watch a Future Shop associate upsell some poor noob on Monster Cables for his brand new home theatre. I'm talking EVERYTHING, from power cables to coax to stereo to HDMI. Had it not meant abandoning my place in an epic line I'd already spent close to an hour languishing in, I might have been able to help. To this day I feel bad. I should have done more .......
Unless you're a hardcore audio enthusiast with hundreds of dollars invested in your speakers, the on-board audio on a good motherboard should be fine.
Sorry but that alone makes me disregard your "proof" and also makes me wonder how "decent" your gear really is (or room acoustics) when you can even tell the difference doing that.I took one of my FLAC files, and compressed it to AAC over and over and over. I had to compress most songs at least 5 (FIVE) successive times to even hear the difference at ~170kbit/s rate, lol. And even then all I could say was it started to sound "different," not even necessarily "worse." I had to compress it 8-10 times to go that far.
That latter part is EXACTLY right. There is VERY little you cant find on a mobo including sound chips from the stone age. It happens alot usually on cheapo boards but sometimes oddly enough on expensive mobos as well...
For instance I wont touch a VIA sound card or onboard. No offense to the company and I hope they compete with Atom in the future and they did make kickbutt mobos back in the day. However, Every time I have heard a VIA sound its crap.
Now of course the best way to avoid all the mess is to use digital and crank up the rate. All sound cards suffer from a harsh EM environment that is inside any PC. Digital makes it far easier to avoid that as light is pretty difficult to affect.
are you talking about via built cards or via in general? i'd like to see what you have that makes a via envy24 based card sound like crap.
As for what makes it and just about any other card sound like crap? Digital...
do you realize what you just said? your digital out doesn't "come from" the realtek because it's still a digital signal. it hasn't been processed. a sound card is a DAC, a digital to analog converter. you have to have something to convert it to analog to listen to it. in your example, you're using the AV R720 to convert it. obviously, a real receiver worth several hundred dollars is going to give you a better sound than a $50 sound card.
i was hoping we could compare apples to apples.
the whole point is comparing sound cards to other sound cards. if you want to spend hundreds of dollars, buying a sound card is obviously beneath you. you're going to be using digital out to a real receiver or at least a usb DAC.
in the realm of sound cards, the via envy24 is a good chip.
My thoughts
- If you listen to music and use digital connect to external amp, a sound card is meaningless
- If you use analog, then a soundcard might help some. But with the advent of HDMI and if you already have a decent reciever... there is almost no reason to go with analog.
- To me, the whole 320 kbps MP3 or AAC vs. lossless issue is the most stark example I've seen of flawed human perception, thought & and the placebo effect. I used to be a FLAC zealot - my music collection was about 100gb FLAC only... one day I was poking around and starting reading up again on AAC and lossy encoding .I decided to try a few lossy encodes to test (I use AAC @~170kbit NeroAacEnc 1.5.3) and ran my own double blind tests. I was not able to even tell the difference on any of the 10 tracks I selected; this on a decent home sound system. I went ahead and compressed my entire collection to AAC and deleted all my FLAC, and my collection is much more manageable... Now I have realized that 99.9999% of the time anyone who says "they can tell the
Digital (Via onboard SPDIF or HDMI or whatever) is not automatically better than Analog. The Digital to Analog conversion still has to take place you've just shifted it farther down the chain. If you are plugging into an expensive HT receiver with a D/A converter better than most soundcards that can be a good thing, but if you are plugging into some cheap logitech speakers or similar, it's probably actually a bad thing. And of course there is still the potential for jitter as well as the actual capabilities of the Digital output, like can it pass 44.1k without automatically re-sampling everything to 48k? Can it do 96k? etc
Your mistake was deleting the flac files. Even if you can't tell the difference, having Flac means you can convert to any format without re-ripping the CDs. If there's some sort of quantum leap in sound or ABC knocks AAC and MP3 off the block as the preferred lossy codec, you run a batch file and you've converted everything while you sleep.
Personally I've got at least 200GB in Flac and if I get around to encoding the CD's I bought over the last 5 years, I'll have another 150gb (give or take). From there, I'll convert to whatever I need. For the time being, I'm sticking with Vorbis, but if I buy a Zune, I'll go to WMA....if I get an iPod, it's AAC. It doesn't matter, because whatever it is, the conversion will happen over night.
Definetly not a mistake. keeping the FLACs while "waiting" for that magical codec would completely defeat the point of deleting them in the first place. I'll be fine with keeping the AAC files, no matter what codec comes out. The improvment can only be incremental. And the Zune supports AAC, as well as any other media player worth anything. Another reason I picked that formet.
Don't expect another codec to come and knock AAC out. We've reached the limits of diminishing returns, and that stared in the early 90's with mp3. Again, keeping the FLAC's and having multiple collections of different lossy files is silly, IMO. AAC will work on anything, computers, consoles, phones, media players.
Woohoo my first 4 page thread. LMAO Usually my topics arent this popular.
I built a newer system with a P55 EVGA board... I tried the onboard sound for about 5 minutes before realizing it was terrible compared to the ASUS Xonar I was about to sell, I stuck that back in there and have been using it since then...
It really depends on your setup and how sensitive you are with music. If you're someone who's content with the stock iPod headphones / cheap stuff... then you'll probably be content with the onboard sound.
Not any more.This could very well be wrong... but from a gamers standpoint, i was always told that you should get a sound card because it takes the stress of the processor? Any truth to that?
Not any more.
I think this question of whether or not to use soundcard or not is something that many people encounters.
I asked myself the same question too with my new build, almost went for Asus Rampage 2 Extreme because it came with a X-Fi card, in the end, decided against it and now I will go for a Gigabyte board instead, with the USB 3 goodies
i still dont understand why microsoft removed directsound from its newer op systems. what a stupid move.
there is NO onboard sound card that can compete with a half decent hardware accelerated add-in card. even when you buy the high-end asus formula board all you get is a shitty softwarebased card....which is a joke. i love windows 7 but id love to jam my old cds up the moron's arse who made the decision to rip direct sound out of windows 7. its the equivalent to any game made now that doesnt support widescreen....makes no sense.
