A lot of things are 'better'.some people say that the ae-9 is better from ae-5
Air is hearing the environment the recording is made in. ie reverb/reflections of the sound in the room.what you mean is missing a lot of air and micro detail??
do you believe that the ae-9 is better from the ae-5/?
Even the HD650 or Massdrop HD6xx are good enough to get some benefit.LCD-X or maybe HD800S...
can you explain me in technical terms ?/ i will understand it..
can you tell me in technical terms why ae-9 is better from ae-5/?
Likely, but that's why I was asking what the OP is 'missing'.Even the HD650 or Massdrop HD6xx are good enough to get some benefit.
Soz, I wasnt sure why you posted them.Likely, but that's why I was asking what the OP is 'missing'.
I mention the LCD-X and HD800S as the best, uh, 'attainable' examples of an all-around headphone in the Audeze, and the most detailed, most open headphone in the HD800S.
For gaming, higher end sound quality is not a major concern.what is your opinion for my dt990 pro and akg712 pro?? do you believe that these 2 headphones which i have are very good for gaming?
lol, they are both decent quality for the price.
We need to understand why YOU are looking at the AE-9, what is it that you want to be better?
Are you looking to upgrade your headphones or hifi?
If so, around how much are you looking to spend?
