Is it worth going from 6700k to Ryzen 3000 ?
OrangeKhrush
As was suggested above, he really needs both upgrades for his usage in streaming. The OP further suggested he doesn't overclock and it is probably due to the 6700K out the box being a poor clocking part, the Z170X should be able to take the CPU to max OC for a 6700K which is around 4.8ghz. Since the OP is running stock it is pretty much a clean sweep here for the Ryzen 5 3600 which is going to net superior results across the board with pretty good streaming performance, if he is already running into limits with his current setup streaming will tax the setup even more.
Ryzen 5 3600 + X570 or X470/B450 if cost saving as well as a jump to a RTX 2070 Super will be in or around $600-700, going just with a RTX 2080ti is alone $1100 and a R5 3600 with 2070 Super is probably better than a stock or OC'd 6700K with 2080ti as the CPU will bottleneck the GPU long before it reaches its limit. In streaming and intensive workloads the 3600's SMT is going to crush the 6700K without breaking a sweat.
If you choose to go with the GPU for now you will get performance increase naturally with a better GPU but your gaming experience is going to be curtailed by the limits of a stock 6700K, your real solution is a full system update to Intel or AMD newer parts even if you do it in steps.
Stryke1983
If you are mostly gaming then a GPU upgrade, no question about it. If you are more concerned about streaming then it becomes both.
My recent upgrade from a 2500k to a 3700x was far less noticeable than when I went from a 1060 to a 2080 two months earlier. However I am also at 3440x1440.
Reactions: TMCM
Fremunaln
Excellent point.
Depends on the game and ideal resolution the OP intend to playon or in the simplest terms, is the GPU bottlenecked by the the current setup of games? Typically a gtx 1000 series cards are setup well for anything where the cpu gen king in the mainstream was 4C/8T.
somebrains
Seems to be a very popular question, I’m seeing it everywhere these days.
Reactions: TMCM
somebrains
They're not the only site to make the AMD price break official. They juts didn't pretend it was part of Prime Day, so Newegg isn't sold-out yet.
https://www.newegg.com/amd-ryzen-7-2700/p/N82E16819113498
I'm not sure CPU prices will much lower.
Ryzen + has more going for it than Ryzen 1 as far as market appeal.
Probably see more B450/X470 inventory depletion offers tied to CPUs.
Having owned both a 7700k and a 2600 used with a 1080ti it's still a "meh" decision btw 2 CPUs if you are just gaming.
I spend more debug time on AMD platforms, take that for what you will.
kasakka
Lots of good info guys. I appreciate it. At some point i will upgrade the GPU, but not sure when. Its not as simple as just buying the GPU, i have to factor in a block and backplate. Strix super is going around 550, plus another 200 in cooling hardware.
When i do upgrade the gpu it will be a 2070 super. Id like to try the next generation of amd, but then i lose gsync.
Will probably 6 months before full upgrade, damn engagement ring
It's probably not even worth buying any of the AIB cards other than cheaper reference designs for the 20xx series. It's not like in older cards where there is a big difference due to better components etc, it's mostly just better coolers that make a noise vs throttling difference.
I have a 6600K @ 4.6 GHz paired with a Palit 2080 Ti Gaming Pro (reference board) and an AIO cooler mounted on it. The card is not a great overclocker even with the AIO but for me it being silent was more important as the stock cooler was a bit loud. I went with this card because it was one of the cheapest A-chip 2080 Ti cards on the market at the time.
I don't stream but overall the system runs the games I've played in the last 6 months just fine. Quantum Break, RE2 remake, Witcher 3, GTA V, Sekiro, Yakuza Kiwami 2, Shadow of the Tomb Raider...all fine but I understand I am leaving some performance on the table so I plan to upgrade to 3700X when they get all the driver and BIOS mess sorted out.
In your case I'd upgrade the GPU first as that would give you the biggest improvement in gaming performance.
