You can lower SA voltage/set it to static/set an offset.the 14th gen do have vccsa bug, it doesn't impact all cpus though.
Reading more, seems more an asus problem since 2 users I just saw don't have issue with tachyon or dark, just their apex.You can lower SA voltage/set it to static/set an offset.
I build PC since more than 30 years, I doubt that I lack skillsI understand your choice and it is a good one, the 7950X3D is a very nice processor that you can just plug and play. That's what made AMD jump up.
But to say the 13900k is crap because you can't stabilize its clock speed/heat and you can't stabilize its RAM is just a lack of skill. Yes, I know it's hard and time-consuming, but it's possible.
1X900k(s) are enthusiast-grade CPUs, so it is not just to plug and play.
Of course it takes time , as with any overclock.I build PC since more than 30 years, I doubt that I lack skills
Stabilizing Intel requires too much time and most of the time the stability is only apparent because some "others workloads" may fail.
Stabilizing for AVX2 requires the CPU to run at 250W at least and with that kind of power is nearly impossible to not throttle even with a good 360mm AIO (with a TAMB of 21°C) leave alone in regions where TAMB is higher.
Intel is just crap compared to AMD at this round and bashing AMD because it does not works well is simply stupid and surreal.
AMD Just Works! You can't tell the same for Intel
https://www.techspot.com/review/2821-amd-ryzen-7800x3d-7900x3d-7950x3d/
Techspot did an in-depth dive on the bastard child that is the 7900X3D, including testing out how a hypothetical 7600X3D would perform. In the context of this thread, my primary takeaway is that while some games can definitely take advantage of 8 cores, more than 8 cores definitely does not benefit any current game. 33% more cores gets you at best 15% more performance and more often less than that.
that's not really true.
that article seems a bad cut and paste from this video:
View: https://www.youtube.com/watch?v=Gu12QOQiUUI
as you can see there are various games that benefits from more than 8 cores like Spiderman, Horizon Forbidden West, Hogwarts Legacy, Star Wars Jedi Survivors, Counter Strike ecc...
8 cores is becoming the new old and I think that it will not be sufficient in the next 2 or 3 years...
games like Horizon Forbidden West started to have ingame shader compilation (even pre-game compilation), add direct storage that will stress this situation even more...
Bingo after trying so many 13th and 14th Gen CPUs, they have degradation and stability issues. You absolutely need a 2 DIMM board and please no Asus for faster than 6000 RAM and if even that.
AMD is more stable and better and uses much less power thus much less heat dumped into the case and easier for quiet system and air cooling.
Intel 10nm process at the high end is fragile and not good. Mid range and lower not as big deal because power and thermal headroom so much more as less cores and will not be noticed. But high end even at Intel stock power limits 253 PL1 and PL2 and 307W current limit degradation is still a thing and no one knows why or whole story.
As for the topic, dual CCDs have cross latency issues.
The single CCD AMD CPUs are best bet.
7800X3D works best as single CCD like no game benefits from more than 8 cores or marginally at best. And it is stable and uses so little power and little heat dumped into the case.
But if games start to scale to more cores please AMD or Intel we need a 10-12 core CPU on a single CCD/ring.
I don't agree completely on this...
HwUnboxed made a good video where you can see that some games is starting to leverage more than 8 cores, giving some benefits to 7950X3D.
All in all 7950X3D is the best gaming CPU currently and the more "future proof" if money is not a problem.
View: https://youtu.be/Gu12QOQiUUI?si=FcR5KBN6JVd6uLPN
don't forget about Direct Storage and in game Shader Compiling that are more and more present in games,
fast assets loading + shader compilation will require more cores since that is a highly parallel workload.
People say this a lot. But.....show me some data on some scenarios where that latency actually matters enough that it performs notably worse?--------because I haven't seen it.Its got dual CCDs so cross CCD latency penalty which is not good in all situations and need to use stupid XBOX Game bar.. Why oh why is there no CPU with more than 8 P cores on a single ring/CCD?
Also degradation is very real on 13th and 14th Gen and no one seems to know what stock speeds are:
https://www.overclock.net/search/1432718/?q=degradation&t=post&c[thread]=1807439&o=relevance
View: https://www.youtube.com/watch?v=kQjMkr013Cw
If you google it there are stories of poor quality control and degradation and intel Raptor Lake crashing Unreal games
Heat maybe? I don't know, I would think vcache on both would be ideal and no need for software solutions past wanting to stay on a single CCD. Not sure how 7000 series does with cross CCD comms in general in games, but when I went with an all core OC on my 5950X, cross CCD in games does not cause any measurable micro stuttering anymore. I actually gained a massive (and very measurable) performance boost too.Here is a stupid question for everyone: Why can't AMD put the vcache on the other CCD as well?
This was touched on earlier in the thread. Basically vcache can’t run at very high clock speeds so vcache on both CCDs limits clocks on both CCDs which would result in a significant performance loss in applications that don’t benefit from additional cache. The hybrid model is a way for AMD to limit some of that performance loss by allowing at least one of the CCDs to clock higher.Here is a stupid question for everyone: Why can't AMD put the vcache on the other CCD as well?
Very expensive to make and to sell. Marginal benefit in vcache sensitive apps (primarily gaming).Here is a stupid question for everyone: Why can't AMD put the vcache on the other CCD as well?
People need to stop saying "best of both worlds" it isn't. It's a compromise. a 7950x3d is still slower than a 7950x in most non-gaming scenarios. Best of both worlds means just that. BEST. It would have to be faster than a 7950x in non gaming workloads and faster than a 7800x3d in gaming workloads.This, it's a best of both worlds situation. Basically for clock sensitive apps, they start on the non vcache cores and spill to the lower clocked vcache cores only if needed (in which case the clock drop is much smaller than if they started the other way), while also providing large cache for apps (games) that get a bigger benefit from that. If they did both cores vcache, games wouldn't benefit as they rarely exceed 8 cores and most other apps would be slower. Plus it'd be more expensive to make. If there were no clock penalty for the vcache, then yeah, put it on both.
That link is about overclocking degradation. Which has always been a real thing. And AMD is affected by it, as well. We have AMD users in this forum whom have experienced it.
There is very recent news of i7 an i9 possibly not being able to sustain their stock spec. And that is different from OC degradation. And definitely concerning.
Its likely Intel WOULD have 10 P cores on their CPUs, if they didn't use so much power and generate so much heat. But, they haven't been able to fix that for 4 generations...
Regarding this: "Intel could have 10-12 P cores no problem as 1 P core is similar in power to 4 e-core cluster"1% and 0.1 lows tank because of it.
I mean look at benchmarks and see how 7700X outperformed 7900X and 7950X because of dual CCD issues in early Zen 4 benchmarks
Intel could have 10-12 P cores no problem as 1 P core is similar in power to 4 e-core cluster. Though their 10nm node is absolute crap and fragile and degrades too easily and has such high power consumption it dumps way too much excess heat into case and too many quality control issues that I may not get it anyways after some experience.
In Techpowerup's 7950x3d review, which is titled "best of bothering worlds":People need to stop saying "best of both worlds" it isn't. It's a compromise. a 7950x3d is still slower than a 7950x in most non-gaming scenarios. Best of both worlds means just that. BEST. It would have to be faster than a 7950x in non gaming workloads and faster than a 7800x3d in gaming workloads.
.....well, no. Its not that simple. Run your 12th/13th/14th gen CPU through blender or cinibench and record the temps.
Now disable the E-Cores and run the tests again. The temps will be very similar, if not the same.
I don't think cooling 10 P-cores would be realistic. And certainly not 12.
Well again, no. You see the same behavior with a 13600k, which does 5.1 max, whether its 1 P core, all cores, or 6 P cores. You still see similar temps between all cores and no E cores, on a 13600k. And that's only 6 E cores.Thats only because the 8 P cores without the e-cores clock higher because of more thermal headroom.
Correct. But, I think they would probably have to clock way down with 10 and 12 cores, to keep the temps in check. It would still be better for highly threaded workloads. Such that, its probably more manageable overall, to do 8 E-cores.12 P cores all would clock lower to compensate in all core workloads and have similar power draw. Its like all cores on 7950X clock lower than all cores on 7900X because there are more of them. Same with 5950X vs 5900X.
It would be a very expensive CPU few people would buy. There's no performance benefit to having 16 V-cache cores. In fact, it would be a performance penalty in productivity apps.Here is a stupid question for everyone: Why can't AMD put the vcache on the other CCD as well?
Almost none, and the games that do benefit from additional cores only benefit marginally. Hardware Unboxed/Techspot did a comprehensive review that is linked above (you can also check out the 7900X3D thread). They even went so far as testing a hypothetical 7600X3D (6-core vcache) by disabling the non-vcache CCD on the 7900X3D. Here are the highlights:I am not a hardware engineer, so this is a guess at best.
The design was meant to satisfy people that wanted the best of both worlds, a fast multi core cpu that has more than 8 cores, and can clock higher than the 7800x3d, and also people that want the best when it comes to gaming. So one chiplet to handle gaming scenarios, and then both chiplets for multicore work loads that can utilize more than 8 cores, which the non X3d chiplet being able to clock up to 5.6-7 ghz also on non cache intensive workloads. I would also assume that games that will use more than 8 cores will suffer from the latency of going across the chiplets, which would also negate the benefit of having the 3D Cache there.
Do we have games that can take advantage of more than 8 cores yet? (Maybe Star Citizen?)
1. Comparing the hypothetical 7600X3D to 7800X3D, the largest performance difference was about 15%. 33% more cores nets at most a 15% performance boost and often less than that.
2. Out of the 12 game test, only 4 was faster on the 7900X3D as compared to the 7800X3D. With the exception of CoD MW2 at 7%, it only does better in those games by less than 5%. The remaining games it loses, sometimes by up to 15%, barely doing better than a 7600X3D.
3. The 7800X3D and 7950X3D trade blows for the top spot but are always less than 10% apart.
4. All of the X3D parts are faster for gaming than their non-X3D counterparts by about 15% on average.
8 vcache cores are basically the most games can take advantage of at the moment. There might be some advantage with 10 vcache cores but the scaling won't be linear since we already don't see linear scaling going 6 to 8.
Dude literally said where to find this info in the 2nd sentence of the post you quoted.Which games marginally benefit form more than 8 cores? Would it be Cyberpunk Spiderman Remastered and its addons like Miles Morales and The Last of Us Part 1 and Starfield and Dragons Dogma 2 be such examples of games that may marginally benefit form more than 8 cores?
E-core generate more heat by die mm no ?Regarding this: "Intel could have 10-12 P cores no problem as 1 P core is similar in power to 4 e-core cluster"
Because of the arch change between the > 8core cpu with AMD and other difference I am not sure if using benchmark tell which game benefit from more than 8 core or more but we can find which does on AMD (say maybe they take advantage of the 9-10 core but not enough to make up for it mean in term of using 2 chiplets, lower freq, etc... do they take advantage of having more core or a larger amount of cache, 7900x double the L3):Which games marginally benefit form more than 8 cores? Would it be Cyberpunk Spiderman Remastered and its addons like Miles Morales and The Last of Us Part 1 and Starfield and Dragons Dogma 2 be such examples of games that may marginally benefit form more than 8 cores?
Spider man seem to be one, not cyberpunk, Hogwart-Call of Duty
Unique case, but also says you don't need two vcache CCDs. One vcache ccd for gaming and one regular CCD to take care of background tasks is sufficient.The main benefit from having >8 cores for gaming is if you do some form of multi-tasking while gaming. I play Warzone often, both my i7 9700k (8 cores) and R9 5900x (12 cores) can run it fine playing solo. However, when I squad up and playing quads while on a Skype video call, there's a significant performance loss on the 9700k, 5900x doesn't care. This is one of the reasons I personally don't subscribe to "you don't need more than 8 cores for gaming" I do quite a lot with my PC and I personally will benefit from >8 while gaming even if the game, strictly speaking, may not.
This is obviously anecdotal. 7800x3d is far more powerful than a 9700k. I'm CPU limited in WZ on the 9700k even with nothing else going on. It also doesn't have SMT "hyperthreading" to help it out like the 7800x3d does
The precise benefit of going AMD. Platform longevity.I will be upgrading from my 13900ks to the upcoming Ryzen 9000 series. Hopefully a 9950x3d...I already have a motherboard for it assembled with a case and a PSU. Will just transfer my RAM and GPU from my current system and I am off to the races.
Hardware acceleration is whatever the default setting is which I’m almost certain is enabled. Still uses cpu cycles, not really a problem on modern CPUs but older 8 cores with no SMT that are already pegged, you notice it.Unique case, but also says you don't need two vcache CCDs. One vcache ccd for gaming and one regular CCD to take care of background tasks is sufficient.
I'm also assuming you have hardware acceleration for Skype disabled as that will shift the load from GPU to CPU.
The Infinity Fabric can't handle it, the transfer would be really huge if it needed to transfer AND the cache from the 3D cache through it for the transferred thread.Here is a stupid question for everyone: Why can't AMD put the vcache on the other CCD as well?
