is it possible to share internet from phone to pc? using htc touch pro2
iceredwing
always wondered if this was possible since it was possible for the phone to get internet from th pc. i just want to know if it is possible to do it the other way around
UICompE02
SCSI Master
You can try this also, all the features of wmwifirouter, but free and, in my opinion, easier to set up:
HTC CM Wifi Sharing
The USB port method will drain your battery much less quickly (and will, in fact, charge it from the USB port). On most newer HTC devices, you just have to plug in the USB port and select "Internet Sharing" from the menu that pops up.
haadij404
yeah thats what I do with my HTC Touch. Pretty decent speeds as well (1Mb down and 250k up). more then enough to browse.
