Is it possible to recover deleted files?
Discussion in 'Operating Systems' started by rkf76, Feb 2, 2008.
  1. rkf76
    rkf76 Limp Gawd
    173
    Dec 3, 2005
    I just deleted some files off my computer that I need back, is there a way I can recover them?
  2. xxEIEIOxx
    xxEIEIOxx 2[H]4U
    2,281
    Feb 1, 2008
    There are programs that will recover deleted files, however, there are no guarantees they will recover all of them if any. Try not to use that machine until you find some software you want to try, as the data may be overwritten. O&O Software makes a data recovery tool, though it is not free and I am not sure how effective it is. Good luck.
  3. OldMX
    OldMX 2[H]4U
    3,533
    Mar 17, 2002
    Recuva for free, GetDataBack for commercial, see which one suits you better
  4. -Dragon-
    -Dragon- 2[H]4U
    2,320
    Apr 6, 2007
    If you have vista there's always previous versions which is possibly one of my favorite features, for XP, see above.
  5. jwhazel
    jwhazel Limp Gawd
    387
    Apr 22, 2007
    Freeundelete by officerecovery.com. Like others said, there is no guaranteed way without shipping it off to a data center for a $2000 recovery. But this program has worked pretty well for me.
  6. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    10,964
    Sep 6, 2007
    Recuva and NTFS Undelete have worked great for me, and both are free.
  7. Mithent
    Mithent [H]ard|Gawd
    1,616
    Dec 19, 2007
    If you can, install one of these programs to a different partition and use the machine as little as possible until you try the recovery - the less the hard drive is 'disturbed' the lower the chance that something will be written over your data.
  8. l3ender
    l3ender [H]ardness Supreme
    5,363
    Jan 1, 2007
    Recuva or Restoration both do the trick.
    As said, avoid using the same HDD that you deleted data off of.
  9. Ndel
    Ndel Limp Gawd
    154
    Feb 3, 2008
    I accidently deleted a lot of data on my media drive, you dont want to know how much. I used getdataback and I was able to recover all of it.
    Ofcourse it was a seperate drive, and I had only deleted the drive not formatted. Also I turned off any services on that drive that would take up metadata.
    I can vouch for getdataback
  10. DeaconFrost
    10,964
    Sep 6, 2007
    I'm not sure about the others, but Recuva has a portable version, and I use it on my PortableApps flash drive. That eliminates the "issue" of installing it on the same partition you need to recover data from.
  11. l3ender
    5,363
    Jan 1, 2007
    Restoration is portable as well. And the only way I know of getting Recuva as a portable is to install it first and then copy the .exe...or get the .exe from someone else. Which is a complete pain. You don't need to worry about this with Restoration.
  12. DeaconFrost
    10,964
    Sep 6, 2007
    The portable version is right on the very same download page as the installable version.
    http://www.recuva.com/download/builds
  13. Arkades
    Arkades n00b
    1
    Feb 1, 2008
  14. l3ender
    5,363
    Jan 1, 2007
    Doh, I never noticed that. I always clicked the downloads page and went to FileHippo. Thanks for the heads up. :)
