Is it necessary to align an SSD after cloning?
Discussion in 'SSDs & Data Storage' started by Rob94hawk, Aug 10, 2018.
  1. Rob94hawk
    Rob94hawk [H]ard|Gawd
    2,038
    Jul 20, 2002
    I just cloned my old 320 GB 5400 rpm HDD to a 480 GB SSD. The HDD was failing & had bad sectors so I used two different programs to clone the HDD to the SSD. I only did this because Macrium refused to clone C: but not the other partitions. Then I used AOMEI to clone C: cause it was the only program that would clone a corrupt HDD.
    To make a long story short, the new SSD works just fine. The question is, do I need to align it now? Thanks.
  2. faugusztin
    faugusztin 2[H]4U
    2,607
    Mar 9, 2008
    What OS made the partition on the original drive ?
    Windows XP or a random software = yes, you need to align it to 4k boundary, because otherwise every write operation must clear 2 cells and write 2 cells.
    Windows Vista and newer = partitions are alligned by default.
    Check your alignment using one of these steps : http://www.ccboot.com/how-to-check-whether-the-hdd-is-4k-aligned.htm
  3. Rob94hawk
    2,038
    Jul 20, 2002
    Windows 7
  4. faugusztin
    faugusztin 2[H]4U
    2,607
    Mar 9, 2008
    If Windows 7 made the partition, then it should be alligned by default. You can still check according the guide, just to be sure.
    Maxx likes this.
  5. Rob94hawk
    2,038
    Jul 20, 2002
    Your link is for a HDD. Don't know if it makes a difference or not. But I found this link, which is what I did.
    https://www.howtogeek.com/270358/ho...id-state-drive-by-re-aligning-its-partitions/
    And according to this link my partitions, which are divisible by 4096, are aligned so that solves that.
  6. faugusztin
    faugusztin 2[H]4U
    2,607
    Mar 9, 2008
    HDD or SSD makes no difference from OS side. Only difference is TRIM support, which has nothing to do with partition alignment.
  7. ncjoe
    ncjoe Limp Gawd
    137
    Feb 16, 2016
  8. Rob94hawk
    2,038
    Jul 20, 2002
  9. PliotronX
    PliotronX [H]ard|Gawd
    2,020
    Aug 8, 2000
    As a quick check, IIRC the starting offset needs to be divisible by 4096:
  10. Luke M
    Luke M Limp Gawd
    323
    Apr 20, 2016
    I don't recall ever reading anything about alignment from the SSD manufacturers. But it wouldn't surprise me if an SSD worked better with at least 4K alignment. That's been standard practice since Vista.
  11. daglesj
    daglesj [H]ardness Supreme
    4,920
    May 7, 2005
    I used to pay attention to it a lot in the 'olden days' but 99.99% of software/OS/systems nowadays appear to just take care of it.
  12. Maxx
    Maxx [H]ard|Gawd
    1,331
    Mar 31, 2003
    You ABSOLUTELY need 4k alignment on any SSD. There's definitely a performance hit. AS SSD will tell you if the drive has the proper alignment. Cloning software like EaseUS has a setting to align to 4k. If you're attempting to re-align an OS drive after the fact, I do not suggest doing it in-line but rather duplicating it to another drive and then aligning it back in a cloning process.
  13. daglesj
    4,920
    May 7, 2005
    I had a NVME drive that wasn't aligned for a month. It was then fixed and re-benched.
    No change in performance.
  14. Maxx
    Maxx [H]ard|Gawd
    1,331
    Mar 31, 2003
    It only affects writes. It can definitely have an impact. I have six SSDs in my main system and recently tested them since I just bought a few new ones and was transferring things. Performance hit on AS SSD was pretty significant, but even if "real world" performance is not greatly impacted it still means more host writes. But this is for older, AHCI drives...nevertheless, better safe than sorry.
