Is integrated good now? (Aorus amp-up vs x-fi titanium)
Discussion in 'Computer Audio' started by Mode13, Jul 14, 2019.
  1. Mode13
    Mode13 Gawd
    564
    Jun 11, 2018
    It's that time of the decade for me to upgrade (every 5 years). For my last two builds I have reused my Creative SB X-fi Titanium pro fatality card due to it's superior analog output - which was vastly superior to the integrated audio on my z97-pro
    The X570 Aorus Elite im ordering boasts about its amp-up audio, but as usual I'm skeptical.
    Should I plan on using my sound card again or is integrated finally adequate?
    Can't afford a usb dac/amp atm unless something incredibly cheap will be significantly better than the x-fi (still using senn 595s)
  2. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,802
    Jan 1, 2008
    Just use your XFi, it’s mostly marketing in the motherboards.
  3. Mode13
    Mode13 Gawd
    564
    Jun 11, 2018
    I figured as much. Was hoping to free up some room for a 10gbe card soon so I suppose I have to start saving for a USB dac..
    I'm so far behind in PC audio, I have no idea what's available. Not willing to spend over $300 on that new SB card. Just way too expensive for me.
  4. GotNoRice
    GotNoRice [H]ardForum Junkie
    9,186
    Jul 11, 2001
    I would strongly lean toward continuing to use the X-Fi personally. That being said, you will be in a position to be able to try both with no additional money spent. I would suggest trying both and seeing what your ears tell you and what actually works best with the gear that you have.
    tungt88, xmadror and Mode13 like this.
  5. Dan_D
    Dan_D [H]ard as it Gets
    54,258
    Feb 9, 2002
    Integrated audio has improved considerably in the last five years. Whether or not its good enough for you is hard to say. Regardless, I'd probably keep using the X-Fi. It's going to be better anyway.
  6. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,291
    Jun 13, 2003
    USB DAC/Amp ---> done, if what's built-in doesn't fly.The HD595's are easy to drive so that likely won't be an issue.
  7. Wade88
    Wade88 Limp Gawd
    197
    Jun 21, 2015
    USB or spdif dac and amplifier works fine, as does an audio/video receiver plugged into your graphics card's hdmi out.
  8. OFaceSIG
    OFaceSIG [H]ard|Gawd
    1,973
    Aug 31, 2009
    I would say it depends on what you're doing. If you're listening to music, or producing it, a USB DAC will most likley be better.
    If you're gaming, the X-Fi with a decent set of head phones will be better than onboard, IMO.
  9. Dan_D
    54,258
    Feb 9, 2002
    I use an optical out from the motherboard to a receiver. This works very well.
  10. Wade88
    Wade88 Limp Gawd
    197
    Jun 21, 2015
    Yeah I'd do that but my spdif is occupied by the DAC at my desk. mini trs for 5.1 at the desk, spdif for dac and amp/cans, hdmi for the receiver. I love desktops very much.
  11. IdiotInCharge
    11,291
    Jun 13, 2003
    Get USB to SPDIF? I get the HDMI, but analog out of the motherboard at the desk? Yuck :)
  12. Wade88
    Wade88 Limp Gawd
    197
    Jun 21, 2015
    It's the optical cable/port to the DAC, it works fine. WTF do you care about optical or USB for this? Both are just pushing bits to a digital to analog converter. the 5.1 is cheap only for positional crap in the videogames.
  13. IdiotInCharge
    11,291
    Jun 13, 2003
    I don't?
    This is what I was talking about ;)
  14. Wade88
    Wade88 Limp Gawd
    197
    Jun 21, 2015
    hdmi out to a avr and a rbh 7.1 system in 2.1, 5.1, or 7.1 with a rythmik 15" for couch gaming and things. the mini trs is fine for hearing if some dipshit is about to shank me in the back.
