Is Cooling necessary on M.2 SSD?
Discussion in 'SSDs & Data Storage' started by Happy Hopping, May 17, 2017.
Is cooling necessary on M.2 SSD (SATA or NVME)
  1. Yes
    17 vote(s)
    37.8%
  2. No
    23 vote(s)
    51.1%
  3. with or without cooling, No difference
    5 vote(s)
    11.1%
  1. STR
    STR Gawd
    540
    Nov 10, 2005
    Well, I've found one way to cool a M.2 drive...an EVGA GTX 1080 Ti. Card only runs at 50-55c, so the exhaust tends to *cool* my SSDs and keep them from going over 48 or so, about 3-5 degrees less than they did with my GTX 970 blower card.
    Downside: this solution is a bit pricier than a couple of stick on heatsinks.
    Upside: You could toss in the heatsinks and barely notice the increase in your shopping cart total.
    [​IMG]
    ChoGGi likes this.
  2. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,186
    Jul 1, 2004
    Instead of a video card, you do know they sell PCI E card, in which the card itself is nothing but 2 x giant fans
  3. STR
    STR Gawd
    540
    Nov 10, 2005
    Lemme check how many PCIe slots I have left...
    [​IMG]
  4. Happy Hopping
    6,186
    Jul 1, 2004
    if it were watersport, it should bring the temperature down further :D
  5. Skylinestar
    Skylinestar Limp Gawd
    295
    Jun 14, 2011
    I would love to install an M2 drive but the slot is just under the graphics card. My room ambient temperature is 95F and I'm worried it will be detrimental to an M2 drive if it's designed in such a bad spot on a mobo.
    Should I be worried?
    [​IMG]
    DF-1 likes this.
  6. Happy Hopping
    6,186
    Jul 1, 2004
    to me, the risk of a SSD failure is very worrisome. And since the cost to prevent it is quite low, and that those heatsink is easy to install, I am in the midst of digging the memory pack brand or equivalent to make it happen
  7. STR
    STR Gawd
    540
    Nov 10, 2005
    Let me put it this way: no matter what temperature, a M.2 SSD is still less likely to fail than a spinning hard drive in the same case.
    Also, does your board support using your GPU on the 2nd or 3rd PCIe x 16 slot? The more space between those components the cooler the temps.
  8. vegeta535
    vegeta535 [H]ard|Gawd
    1,337
    Jul 19, 2013
    How do you live/work in a room that is 95F @.@
  9. Happy Hopping
    6,186
    Jul 1, 2004
    go w/ what STR said. I did the same thing. Not for m.2 reason, but because my giant CPU fan blocks the 1st PCI e x 16, so I use my 2nd PCI e x 16 slot
  10. Happy Hopping
    6,186
    Jul 1, 2004
    Anyhoo, say you have a dual fan on your video card, and your fan is blowing air next to your m.2 SSD, like the above ASRock photo. Is the fans on your video card blowing hot air towards your M.2? because the fan should circulating air, and what comes out, should be hot air. If so, doesn't that makes your m.2 hotter?
  11. STR
    STR Gawd
    540
    Nov 10, 2005
    Depends on how hot the air coming from the GPU is. If your GPU stays at 50c (like mine), the air coming off the card is probably about 40c. 40c air will still cool a SSD running at 50c.
    25c air will cool a SSD better, but that doesn't mean the GPU is making things hotter.
  12. Skylinestar
    295
    Jun 14, 2011
    It's hot as hell (humidity at 85%) but there's nothing I can do other than spending on electricity bills with AC running 24/7. At that temperature, I'm always sweating. Wearing headset for gaming is impossible (ears sweat). Heck my working site (fixing pressured vessel) is 110F.
  13. STR
    STR Gawd
    540
    Nov 10, 2005
  14. Happy Hopping
    6,186
    Jul 1, 2004
    I am thinking of this idea: I have a Lamptron fan controller. It c/w 6 sensors. Assuming I get some heatsink, I can use cable ties to tie the sensor to the heat sink on the M.2 SSD, that way, I would know the exact temperature.
  15. ChoGGi
    ChoGGi Gawd
    980
    May 7, 2005
    SIV (system info viewer) will show you the temp the drive reports.
    I know you can use it to auto adjust fan speeds with a corsair commander mini or a nzxt grid v2, but no idea about that lamptron.
  16. Happy Hopping
    6,186
    Jul 1, 2004
    Not w/ Lamptron. But it's very simple. You see the display at 30 deg. C, you're happy, if it's at 40 deg. C, you turn up the dial
  17. STR
    STR Gawd
    540
    Nov 10, 2005
    I have my SSDs report their temp to SpeedFan, which will ramp up the fans on a curve from 38c (min speed) to 45c (full speed).
  18. Happy Hopping
    6,186
    Jul 1, 2004
    my next motherboard will have 2 x 140 mm fan blowing on the 2nd m.2, so no problem there. But it's the 1st m.2 that is sandwiched between the sound card and the video card that it will be a concern. Because a 2 slot wide video card is sitting next to it. So I'm not even sure if a heat sink is possible
  19. Happy Hopping
    6,186
    Jul 1, 2004
  20. Happy Hopping
    6,186
    Jul 1, 2004
    I dig out an Intel m.2 SSD today, it's 480GB, the chips surface is only as thin as a credit card. It's hard to imagine something this thin creates a lot of heat. But on the other hand, if it does, for chips this thin, wouldn't it be easy to burn out the chip?
  21. Happy Hopping
    6,186
    Jul 1, 2004
  22. daglesj
    daglesj [H]ardness Supreme
    4,579
    May 7, 2005
    I just went the copper RAM heatsink on the controller route. Works fine.
  23. STR
    STR Gawd
    540
    Nov 10, 2005
    CPU dies are pretty small, but generate enough heat to boil water.
  24. Happy Hopping
    6,186
    Jul 1, 2004
    photos?
  25. Happy Hopping
    6,186
    Jul 1, 2004
    alright, I'll find a US retailer and order a few of these
  26. daglesj
    4,579
    May 7, 2005
    I switched to black recently because...black!
    [​IMG]
    Idles at 39c/102F and max I've managed to push it to is 57c/134F.
    The sinks were part of a double Raspberry Pi set.
  27. STR
    STR Gawd
    540
    Nov 10, 2005
    Only if the SSD reports temps that you'e uncomfortable with. Before adding heatsinks, my SSDs would peak at 50c. That's well within specs (70c max operating temp). With heatsinks, they peak at about 40-42c now with an overclocked GTX 1080 Ti blowing hot air on it in a ITX cube 11 inches square. Also well within spec. By all indications, I didn't need to do any of this. You might not have to either.
    [​IMG]
  28. Nebulous
    Nebulous [H]ard|Gawd
    1,216
    Nov 16, 2005
    I noticed my PNY M2 Nvme ran hotter than satan's ass. Idled @ 60-ish and under activity ramped up close to 72-74c. For shits and giggles I put my fingertip on it just to see how how it really was. Needless to say that wasn't fun :eek: So I shopped around and picked up some old school memory heatsinks by Thermaltake from flebay.
    The smaller 2 1/2" sinks are the perfect size and with some thermal tape and zipties I attached it to the M2. Had a 60mm fan in my box-o-junk and mounted it so it would blow air across the heatsink and away from it. Temps on the drive are: Idle = 29c and under activity just blips up to 33c :D
    You'll notice the 60mm fan is to the right of the M2 in the last pic.
    Total cost for cooling: Under $20
  29. STR
    STR Gawd
    540
    Nov 10, 2005
    How loud is the fan?
  30. Nebulous
    1,216
    Nov 16, 2005
    It's an older 60mm fan from the AMD 754/939 days. The blades have an incline curve to them and I can't hear it at full bore :D.
    Lemme see if i can get info from the back of it.
    *Edit* Found it:
    Specs:
    Dimensions: 60mm x 60mm x 15mm
    Bearing: Ball
    RPM: 3,000 RPM
    Airflow: 14.7 CFM
    Noise Level: 24.6 dBA
    Power Connector: 3 Pin
    Rated Voltage: 12 VDC
    Operating Voltage: 10.8 - 13.2 V
    Input Power: 1.2 W
    Input Current: 0.1A
    RPM Sensor: Yes
  31. westrock2000
    westrock2000 [H]ardForum Junkie
    10,230
    Jun 3, 2005
    On Intel 600p, moved sticker to backside.
    Used these two things
    [​IMG]
    [​IMG]
  32. Nebulous
    1,216
    Nov 16, 2005
    That's kinda permanent isn't it?
  33. Happy Hopping
    6,186
    Jul 1, 2004
    how much is the thermaltake and exactly how does it stick to the SSD?
    how do you mount that 60 mm cooling fan? Cable ties?
    P.S. You could remove that warranty sticker first
  34. Happy Hopping
    6,186
    Jul 1, 2004
    see, this is why I'm seriously thinking of putting the video card at the x8 link to avoid your problem
  35. Nebulous
    1,216
    Nov 16, 2005
    1) The 2 Thermaltake mem sets were $14
    2) Thermal tape & zipties
    3) Used a pci slot cover and bent it into a clip. fan screwed on, then clipped into place
    4)Yes, already removed before adding sink
  36. STR
    STR Gawd
    540
    Nov 10, 2005
    Umm...I don't have a problem. Everything is, and was always, operating 20-30c below max temps. I just wanted lower temps because...well...that's half the hobby.
    Nebulous likes this.
  37. YeuEmMaiMai
    YeuEmMaiMai [H]ardForum Junkie
    15,416
    Jun 11, 2004
    I have a 2014 Dell Venue 11 Pro with a 256GB SSD and it has lasted just fine with very little cooling
  38. Happy Hopping
    6,186
    Jul 1, 2004
    Update:
    I have go thru ebay, amazon, newegg, etc. , the only place that has the aqua computer kit from Germany is Amazon of UK. It seems no USA dealer carry this item. Anyone has any suggestion?
  39. rsquared
    rsquared Limp Gawd
    454
    Jul 5, 2007
    Performance-PCs carries EK's M.2 heatsink, just like Aqua Computer's except with a big ol' EK logo on it: link
  40. Happy Hopping
    6,186
    Jul 1, 2004
    thank you very much. Half of the people in this thread are looking for that.
