DaedalusHelios
- May 19, 2008
Is there a waterblock compatible with the Asus P5N-D 750i Northbridge?
I don't know of any, and any advice at all would be very appreciated. If I need to take pictures of it, just let me know, and I will.
There are two chips spread apart under the Northbridge heatsink, and thats why I figured a universal block wouldn't fit it.
I believe the two chips are the SLI chip, and the Northbridge itself, since its 750i SLI.
Here is a link to the board: http://usa.asus.com/products.aspx?l1=3&l2=11&l3=627&l4=0&model=2033&modelmenu=2
Should I take a picture under the Northbridge heatsink for better accuracy?
I am wanting to add a waterblock since the temp of the northbridge reaches 55C before I OC it.
