Is a used CPU worth more or less if it has been lapped?
Discussion in 'Intel Processors' started by Thunderdolt, May 24, 2019.
  1. Thunderdolt
    Thunderdolt Limp Gawd
    257
    Oct 23, 2018
    I have an extra i9 that I'm wondering if I should lap before listing for sale.
  2. mnewxcv
    mnewxcv [H]ardness Supreme
    6,483
    Mar 4, 2007
    I wouldn't bother.
    SticKx911, jmilcher, kirbyrj and 3 others like this.
  3. tom_ozahoski
    tom_ozahoski Limp Gawd
    247
    Feb 24, 2014
    Many people would consider it worth less and possibly been abused or at least not understand the reasoning.
  4. dvsman
    dvsman 2[H]4U
    2,844
    Dec 2, 2009
    Just sell as is and ask if they want the chip lapped, which you can do for extra $$$. You can always lap it later but you can't unlap it once you've already lapped it.
  5. mnewxcv
    6,483
    Mar 4, 2007
    Say lap again.
    AlphaQup, SvenBent, arestavo and 15 others like this.
  6. pendragon1
    pendragon1 [H]ardForum Junkie
    14,359
    Oct 7, 2000
  7. Mode13
    Mode13 Gawd
    663
    Jun 11, 2018
    You would just be removing the lettering identifying what the CPU is. 99% of buyers will be confused by it. Don't do it.
    Parja likes this.
  8. drescherjm
    drescherjm [H]ardForum Junkie
    14,527
    Nov 19, 2008
    Could also open you up for a fraudulent buyer. I mean without markings they can easily swap it with something else. And claim you sent the wrong CPU.
  9. vegeta535
    vegeta535 2[H]4U
    3,347
    Jul 19, 2013
    Yeah sell it as is. Voids the warranty also.
  10. Thunderdolt
    257
    Oct 23, 2018
    Thanks for the feedback. Will list it on [H] as-is later this weekend.
  11. brentsg
    brentsg [H]ard|Gawd
    1,694
    Mar 8, 2003
    Worth more to a much smaller set of possible buyers. Worth less to a larger population. Essentially un-buyable for some people too.
    drescherjm likes this.
  12. somebrains
    somebrains Gawd
    782
    Nov 10, 2013
    Only way to up the value from stock is by having Kingpin clock it, lap it on camera, clock it again to show gains, declare it golden, then include a spec sheet.
    Flexion and Fremunaln like this.
  13. vick1000
    vick1000 [H]ard|Gawd
    1,923
    Sep 15, 2007
    I wouldn't trust it was flat unless I do it my self. Don't lap.
  14. Fremunaln
    Fremunaln Limp Gawd
    150
    May 3, 2019
    unless you find someone who specifically will pay the premium, yea, its a used CPU for all intents and purposes
  15. PliotronX
    PliotronX 2[H]4U
    2,070
    Aug 8, 2000
    I would pop it and put one of the copper lids from ebay for a few bucks on rather than lapping and then thermal epoxy the original back on before selling. Better yet, fix your mount and run bare die like a man :D
  16. Vader1975
    Vader1975 Gawd
    820
    May 11, 2016
    depends on if you are selling to one of us.
    We arn't the regular ebay consumer.
  17. Kardonxt
    Kardonxt 2[H]4U
    3,005
    Apr 13, 2009
    Even being [H] I wouldn't touch a delidded cpu without a massive discount. No telling how hard that chip was pushed, especially if the user felt the need to delid it.
  18. Vader1975
    Vader1975 Gawd
    820
    May 11, 2016
    Lapping a IHS is not the same as Delid. Where are you coming from exactly?
    Regardless I disagree with that as well. If a properly delided Intel from many of the series that Intel did a horrible job with the under IHS compound job was already done and the cpu was validated as fully functional, then the threat of damaging it during the IHS removal has already been passed. So if you are actually [H] then that would be a bonus. Also there are a number of CPU's that the IHS isn't flat. So not lapping it as a [H] would mean you arn't [H] wouldn't it? As extracting every ounce of overclocking headroom wasn't extracted.
    Luckily my current cpu's IHS is flat as a razor and is soldered inside. Thus I don't have these issues but my 3770K was delided and lapped and then went far better than before. Still running it at 4.5Ghz today.
  19. Kardonxt
    Kardonxt 2[H]4U
    3,005
    Apr 13, 2009
    My bad, been a while since I read the op. Have just been following the comments.
    Same concept tho. I wouldn't pay a premium for a defaced cpu that was owned by someone who was chasing performance so hard they lapped it. Much more likely to have had higher voltages \ etc pushed through it.
    If I wanted a lapped \ delidded CPU I would do it myself and make sure it was done right, on a cpu that I know hasn't been abused.
    spine and Thunderdolt like this.
  20. Thunderdolt
    257
    Oct 23, 2018
    This all sounds good to me. At this point, it's an extra CPU (I needed more cores, so I upgraded) and I was just curious if lapping would be perceived as a value-add or something to be avoided.
  21. spine
    spine 2[H]4U
    2,608
    Feb 4, 2003
    If you can actually convince someone that a used and literally scuffed up CPU is somehow worth more, then just quietly take their money and move on. ;)
    fullvietFX likes this.
  22. sethk
    sethk [H]ard|Gawd
    1,662
    May 3, 2005
    You could just offer to lap it for a potential buyer as an incentive to buy from you, if the buyer wants it lapped. Best of both worlds since the buyer is assured it wasn't pre-lapped and abused and if they don't want it lapped - no problem.
    Thunderdolt likes this.
