Is 91% Isopropyl Alcohol Still Alright for Thermal Paste Cleaning?
Discussion in 'Overclocking & Cooling' started by Falling Anvil, Sep 13, 2012.
  1. Falling Anvil
    Falling Anvil [H]ard|Gawd
    1,570
    Nov 3, 2007
    I am going to be switching cases soon, and I thought it would be wise to take the time to clean off and reapply the TIM to my CPU cooler along the way (didn't do a good job the first time around so have been meaning to do that for a while now) . This would be my first time doing this, and I do have coffee filters available, but I am noticing that noone seems to be selling 99% Isopropyl alcohol around here, it's all 70% and 91% if not lower. I've heard that you can still clean thermal paste off with lower concentration solutions, but a lot of these are from fairly old sources so I was just wondering if it was still true.
    I am also changing out from my badly applied Thermalright Chill Factor that came with my cooler to the MX-2 I have lying around, so I was wondering if that might change anything. I'm pretty sure it wouldn't, but I have also heard that some pastes like AS5 leave a residual amount on IHS crevices if cleaned that might affect performance of the new paste.
  2. Methadras
    Methadras [H]ardness Supreme
    6,131
    Dec 19, 2000
    Yes, 99% if you have it. :D
  3. Cruiza
    Cruiza [H]ard|Gawd
    1,721
    Mar 17, 2008
    Yep, I have 91% or something around there and it works like a charm.
  4. tunatime
    tunatime 2[H]4U
    3,019
    Sep 15, 2011
    i even used 77% one time and it worked alright
  5. FaRKle0079
    FaRKle0079 2[H]4U
    2,613
    Jan 11, 2005
    You'll be just fine with 91% or 71%. Just means you'll have to wait a bit longer for the moisture to evaporate.
  6. atarione
    atarione [H]ard|Gawd
    1,971
    Mar 17, 2011
    i am slow when I work so i have used 80% a number of times but since it takes me so long to do this stuff it is well dry by the time I get ready to reassemble :D
    however now I get 91% or 99% just to be more safe.
    personally i generally just clean the cpu ihs with lint free cloth... and not alcohol.. (just use that on the heatsink).
  7. RebelExtrm02
    RebelExtrm02 [H]Lite
    72
    Feb 21, 2009
    I've never had any issues. I currently have 95% that I picked up from Walmart for around $1. I've used it on both my lapped heatsinks and cpu ihs with no ill effects or results. Following up with a lint free cloth is good insurance though.
  8. Falling Anvil
    1,570
    Nov 3, 2007
    This is a necro post, but I just want to update you guys that I recently did the deed with my 91% + coffee filters and sure enough, I got the job done. Well, I think I did a good job on my cooler, got it nice and mirror shiny, but the CPU itself seemed a little rough in texture. Then again, it's probably just how the IHS is. ;)
    Thanks for the reassurances everyone! :)
  9. BababooeyHTJ
    BababooeyHTJ [H]ardness Supreme
    6,947
    Jan 21, 2009
    Its what I use. Works just fine.
  10. ReaperTech
    ReaperTech Limp Gawd
    237
    Sep 27, 2012
    same i use 91% works fine even used 70% no problem just give it a bit of time to evaporate and whats the harm, all that really matters is getting the old gunk off so the new paste does its job properly.
  11. evilsofa
    evilsofa [H]ardForum Junkie
    10,078
    Jan 1, 2007
    The difference between the more pure stuff and the 70% is that the 70% is more effective at breaking up cellular organic material, such as fingerprints, mucus, etc. The water in the 70% version helps the alcohol to penetrate the cell wall better. This doesn't matter so much when removing TIM, but it is better when cleaning monitors, mirrors, etc.
  12. Radical
    Radical Gawd
    750
    Jan 12, 2007
    I've used both 91% and 70%, both have worked just fine as far as I've been able to tell, though I've never tried 99%. I always thought it was recommended to use the highest % you have available because there's less water in it to damage things, not because it cleans any better.
  13. bmoney9
    bmoney9 Limp Gawd
    236
    Jan 16, 2006
    70% has always worked for me. It does its job.
  14. x509
    x509 [H]ard|Gawd
    1,795
    Sep 20, 2009
    In the US, is "rubbing alcohol" 70% or 91%?
  15. travbrad
    travbrad [H]ard|Gawd
    1,253
    Jan 11, 2005
    "Rubbing alcohol" is just the common/slang name for isopropyl alcohol, so it totally depends on the particular bottle. It should say what the concentration is on the bottle's label.
  16. clutch22
    clutch22 n00b
    19
    Mar 16, 2009
    I bought some of the fancy ArctiClean stuff for my last build and to be honest...it didn't work nearly as well as 91% alcohol. It took much longer to clean/dry and still look 'meh' after 3 applications.
  17. travbrad
    1,253
    Jan 11, 2005
    I tried ArctiClean and it worked okay for me, but regular old isopropyl alcohol works a bit better and is a tiny fraction of the cost. A $2 bottle will last you decades unless you are cleaning your CPU every day or something.
  18. SonDa5
    SonDa5 [H]ardness Supreme
    7,403
    Aug 20, 2008
    I have used that and it works well but doesn't last long and is kind of pricey.
    I just recently bought a good size container of Goo Off and some Isopropyl alcohol ("rubbing alcohol").
    When doing direct DIE TIM removal you have to be very careful. To avoid scratching die I do the following.
    When cleaning the die/mount area of TIM I put a few drops of Goo Off on the die and use a microfiber cloth with goo off on it and dab the TIM off. I don't rub. Rubbing IC diamond off can slightly scratch the die and this can happen with metal based tims as well which are abrasive. So don't rub the TIM off. Dab it off. I do this on the block as well.
    After all the TIM is off I then use the isopropyl alcohol with a micro fiber cloth. Similar to the articclean steps in cleaning. Works well and much cheaper than the ArticClean.
  19. bitgod
    bitgod Gawd
    995
    Feb 20, 2003
    But the ArctiClean has a nice lemony scent! :)
