Is 500GB SSD too much for Win10, Drivers, Antivirus, etc..
3WAYsplit
Would a system with either of these storage setups be overkill?
SAMSUNG 850 EVO 2.5" 500GB SSD (Win10, Drivers, Antivirus..)
Seagate Desktop HDD ST4000DM000 4TB (Media, Games, etc..)
or
SAMSUNG 850 EVO 2.5" 500GB SSD (secondary programs..)
I was originally planning on the first setup. But I may end up with the second. How well each one would work?
Would the two SSD setup work ok? I'm not interested in a RAID setup.
SvenBent
Really depends on what "etc" is...
Without the "etc" you could install it on a 60GB SSD..
3WAYsplit
The 4TB HDD will be used to store and play video & audio files, games, media burning programs, media editing programs. Mostly programs & files that don't need to be accessed at SSD fast speeds.
emmjawsX
For just base OS + utility/productivity type programs 250GB is even overkill a little bit. You'll see some benefit in load times from graphically intensive games that load a lot of textures with an SSD, i fill most of my 500GB SSD boot drive and a 500GB SSD storage drive with those. Ultimately it depends how much you want to store i guess.
BlueWeasel
I agree.
I have a Samsung 250gb SSD for my boot drive with Win10, drivers, applications (some quite large like AutoCAD), etc. and only about 80-100GB is being used.
Biznatch
Get the 500 and use it for your games as well. No reason not to... Save the spinner for video/audio files.
thesmokingman
Option 1, though you don't need 500gb for os and apps, 120gb-256gb is enough.
liiroy
120-256 is more then enough, as long as you keep the "etc" on the hard drive.
Darkswordz
Put your games and programs on the SSD. Only use the HDD for storage of music and pictures and videos.
