Jul 14, 2011 #1 D djgizmo [H]ard|Gawd Joined Dec 24, 2006 Messages 1,429 I'm trying to make a video of an app I'm working on but I'm unsure how to perform a screen capture of my iphone. I'm working on a windows platform. Any recommendations for an program to use to screen capture?
Jul 14, 2011 #2 dr.stevil [H]F Junkie Joined Sep 26, 2008 Messages 9,265 Do you mean for video capture or screenshots? Screenshots can be taken by pressing the home and power button together. If you want to record video, there is an app that you can get through cydia that will let you record it right on the device itself. I'll try to look for the name of it for ya edit: the app is called ScreenRecorder
Jul 14, 2011 #3 D djgizmo [H]ard|Gawd Joined Dec 24, 2006 Messages 1,429 I mean video... sorry, I should have clarified. Ok, well I don't have my iphone jailbroken (don't really won't to either). Is there a PC app I can use to screen capture?
Jul 14, 2011 #4 dr.stevil [H]F Junkie Joined Sep 26, 2008 Messages 9,265 Hmmm, not that I'm aware of. If you run OSX though (or a hackentosh) you can use the iphone SDK emulator and record it directly on the computer. If not, jailbreaking is probably your only easy solution. Either that or recording it with a video camera. good luck
Jul 15, 2011 #5 D djgizmo [H]ard|Gawd Joined Dec 24, 2006 Messages 1,429 Sigh... I tried the ScreenRecorder. The video it records has very poor frame rate. I want my $2 back.
