HenryBravo
- Aug 6, 2004
No pun intended? Sorry, couldn't resist.it's definitely related to the topic at hand.
We'll find out soon enough I suppose.
Honestly, I have a bigger issue with the way Apple has handled the PR with this than the issue itself.
I wonder if he could possibly be any less direct.Steve Jobs said:There are no reception issues. Stay Tuned.
Walt Mossberg chimes in on the situation with an interview of Steve Jobs and Jonathan Ives... you might need some tissues for this one <hint, hint>:
http://www.youtube.com/watch?v=k6IHZBXmixY
Very funny stuff...
Considering at least one of Apple's baseband engineers is a drunken, forgetful idiot, this doesn't seem out of the realm of possibility.The fix is expected to address a issue in iOS 4 related to radio frequency calibration of the baseband. Readers who saw the original forum discussions say that the issue is believed to occur when switching frequencies; because the lag is allegedly not calibrated correctly, it results in the device reporting "no service" rather than switching to the frequency with the best signal to noise ratio.
iOS 4 introduced some enhancements to how the baseband selects which frequencies to use, so it makes sense that the error may have crept into those changes. Additionally, this explains why iOS 4 has also caused similar problems for iPhone 3GS users.
Additional readers have shared other related experiences that also corroborate the idea that the issue is related to iOS 4's software control of the baseband, including the fact that the issue seems easily reproducible when connecting to a WWAN 3G network but does not appear when connecting to a Microcell 3G. If the problem were simply hardware related issues of the antenna design, it should only affect iPhone 4 units with that new design and should occur at all times, regardless of the tower type. That is not being observed.
Not sure how a software update would fix a hardware problem.
You could put your finger over the spot that was blocking the signal before and see if it drops the call
The presumption here is that if the signal dropping is just a bug related to visual lag from a frequency change brought on by the presence of the finger. So, no, it's not as simple as that.
What I'm actually getting at is the substance most have missed in the fiasco: when you place your finger on the lower left corner of the iPhone 4 and the signal bars begin to drop, does this actually affect call reception and quality? The widespread presumption is that it does, but beyond one Youtube video, we don't really have a demonstration of cause and effect.
So if 4.0.1 corrects what is purported to be a graphical lag in the signal bar meter rather than an actual, honest-to-goodness drop in reception because your finger is causing mayhem with the antenna, how would you measure the change from 4.0 to 4.0.1 in an honest way? I'm making the assumption here that there are persons and groups who would charge Apple with simply sweeping the problem under the rug if indeed the presence of a finger no longer causes a drop in bar count.
Basically, I'm asking if the people complaining the loudest are simply going to find a new reason to complain upon 4.0.1's release. I can see the screaming headlines now: "Apple disguises hardware problem with software patch!" accompanied by articles claiming that there's still a reception issue even if the bars no longer drop like a rock. Which, you know, would make zero sense, since there would no longer be a way to measure anything of the sort.
This will be mighty interesting.
There are many videos posted showing "holding the phone wrong" severely impacts web browsing performance. In short, the shit doesn't work when holding the phone wrong. We WILL know if Apple is trying to blow smoke up our butts.
Nah, I feel he could use a little more mocking.The guy lost the phone. People aren't perfect. He's been mocked enough.
http://www.youtube.com/watch?v=F6oflC4qo8MThe presumption here is that if the signal dropping is just a bug related to visual lag from a frequency change brought on by the presence of the finger. So, no, it's not as simple as that.
Because the headphone cord will be used to some degree as an antenna simply by proximity, the same way the signal reception would be affected if you placed your hand, or some metallic item close by. The headphone cord at least from the grounding perspective is a part of the circuit...
ryuuzaki said:I did it. It worked.
For those of you who it didnt work for, follow my step by step and it should be fine.
1. Turn off phone.
2. Remove sim and leave it out for ATLEAST 20 minutes.
3. Pop it back in.
4. Turn on phone.
5. Death grip.
Absolutely no loss of signal or bars. I am shocked. This guy should get paid for his discovery.
Hats off to you friend.
