It shouldn't be a problem in the first place though.....take it back and complain so you can get the product you paid for, why bend over and accept it ....
Anecdotal evidence from a user on another forum that actually phoned Apple about this is that they're claiming a manufacturing flaw resulted in a protective coating not being applied, or being applied improperly to the metal surface that would presumably isolate the antenna electrically and prevent this issue. Seems plausible to me, since it didn't seem likely Apple could have missed this.
Apparently Apple is also replacing his phone free of charge.
Hrm, pretty shitty response from Steve, IMO.
http://www.engadget.com/2010/06/24/apple-responds-over-iphone-4-reception-issues-youre-holding-th/
Yah, I was going to share that antenna article link as well but I disagree with some of his speculation. He's dead on with most of it but some aspects just irk me that someone that's supposedly an "antenna expert" would state.
To see if this is the case, can anyone post te first two digits of their serial numbers? They're supposed to indicate which factory your iphone came out of. Mine is "85".
My guess is that it effects all phones currently and that apple plans to revise the design so that the manufacturing process include a coating at some point. Hell, it might even be a clever way to ruin a jailbreak effort (remember how a couple months in, 3GSs had a revised bootrom?). In the mean time, if I'm finding myself constantly dropping calls, I'll apply a thin piece of tape on that spot.
I tested this out on mine yesterday and I couldn't get it to drop a call even when holding the phone right on the lines on both sides of the phone. Maybe I'm lucky, but it doesn't seem to be affecting me.
Domingo & Croozer, I'm just curious... what do your serial numbers start with?
I don't agree with his opinion that the design of the iPhone 4 is "forced by the FCC" and the others he mentioned, I just don't agree at all.
This makes me think about those rubber "bumper" cases Apple will be making for iPhone 4.I don't agree with his opinion that the design of the iPhone 4 is "forced by the FCC" and the others he mentioned, I just don't agree at all. I made note over at MacRumors that perhaps the best antenna design of all for this device would have been to embed the antennas inside the back glass plate, as antennas are embedded in auto glass. Would work just as well if not better even if they chose to use some foil-type embedded element - the main point being that you can't touch an antenna or you're going to totally pooch the properties, the RF absorption, and the propagation all at the same time with totally negative effects.
His comment about the isotropy was interesting but, if people hold the phone exactly as Apple apparently is now saying not to do (based on Jobs' email reply and an apparent "official" word from Apple saying pretty much the same thing), the radio wave propagation is going to be directly into the fingers/palm - the lobes would be firing out from the sides of the plane of the phone.
While this particular design does actually cause the RF energy to fire out perpendicular to the user's head, and could be part of their logic and reasoning for this design change, in the real world it's not nearly as effective as a patch type antenna which has been the prevalent type of cellular phone antenna for many years now. Crack open most any cell phone and you'll find one of those ribbons with the foil-type patch antenna inside mated with some plastic flexible strip.
Personally, if it were up to me to design the antennas, I'd embed the foil-type concentric patches inside the back glass panel and be done with it. Microwave transmissions of these types seems to respond best with a large patch antenna than a single "whip" style of old days.
That writer does note, however, that the isotropy thing would only be effective if the "phone is suspended magically in air" (exact quote) so, put it in someone's hand and all bets are off.
While a number of people are dismissing this as no issue at all simply because they can replicate signal loss to some degree with other phones, as I noted before in another post in this thread I know of no cellular phone on the market today than can lose a signal and service entirely with a touch of a finger as several videos on YouTube and other locations have clearly demonstrated.
Full 5 bar signal (or 4 in some videos) and the phone laying flat on a surface and only one fingertip is applied to that lower left hand seam and wham, the signal decreases, fades, disappears, then service is actually lost completely in some videos.
If a touch of a finger can "kill" the service, how much more proof do people require before they'll break that Cult of Mac programming and step up and admit "Ok, that shit is broken..."
The more I read about this as the day/evening goes on the more I'm lending credence to the potential that yes, there should be and is a coating applied to the metal chassis components that make up the antenna band(s) but only on the outer edges designed to be in direct contact with human skin. I can't find any more proof or evidence so far but, that one ABC TV affiliate report of a guy with a phone exhibiting this issue and returning it and getting another iPhone 4 and testing both right there in the store and his original one lost signal while the "new" one didn't could be the proof that somewhere in the manufacturing chain a ton of these phones simply didn't get that coating.
How else can you explain loss of signal and service with just a fingertip?
Jobs said:All phones have sensitive areas. Just avoid holding it in this way.
There's a rumor floating around that a firmware update on Monday (iOS 4.01) may address the issue but honestly, unless it's flat out disconnecting the antenna I don't see a working solution offered up that fast unless there was a previous knowledge of such an issue that's been in-place for a very long time now.
The rumor I commented on was posted a short time ago on MacRumors in the rather huge (2,200 posts and climbing) thread about this issue, and it wasn't referencing Mossberg at all - the person making the post said the info came from the mouth of the Apple Support tech he was speaking with when he called in to complain about the problem with his brand new iPhone 4 he'd just purchased earlier today.
The Mossberg thing is well known and could be related in some way, but this issue with the signal degradation and loss of service that many folks are now experiencing (as this thread attests) and honestly doesn't seem to have anything to do with the phone showing a signal or not.
