Hey,
I'm looking to pull the trigger on some new stuff very soon (few days) since I apparently got my supplier to get a few more Lian-Li PC-A05b's in stock (3 units) so i need to figure out my config FAST.
My only concern is the heat pipes on the IP35 Pro. Will they not cool as effectively being upside down? Would i be better off with the E version instead of the Pro? My only reason for getting the Pro is the sideways sata ports for better cable management, uguru and the extra x16 pci-e in case i get a 3870 and the slim change i'll do crossfire later on.
Thanks
Thanks
