ip camera setup
antok86
i know my question for this setup is not ideal but right now its only a temp solution. i have a spare unifi g3 ip cam that i would like to possibly pole mount outside of my house but only have access to power. i could buy a cheap wireless ip cam or is there a outdoor wireless bridge that also acts as a poe injector to the g3 cam?
Cmustang87
I'd go with the UAC-AP-M-PRO. It has 2x1Gig eth ports on it and can be pole mounted. I would just get their pole mounted POE injector. I mean, it's not exactly "cheap", but it's a solution. Do you just have a single power outlet?
