faugusztin
- Mar 9, 2008
So,
i'm thinking about developing some apps for iOS, and because of that, there are some prerequisites outside of the $99/year payment to Apple
First, there is an issue of the development computer itself. We can safely rule out the hackintosh route, so the only real choices are :
Then there is a question what iOS device to buy, with strong preference of iPod touch 8GB 4th gen (239).
Of course there is a possibility for "used device market", but i'm not really ready to go that way.
What are your suggestions ? It will be used only for application development (iOS, maybe replacing my current laptop too for J2EE development). If there will be any gaming at all, then it will be TF2 (but this is not a deciding factor).
- 2010 mac mini - 718. The cheaper alternative, but it is only C2D@2.4GHz, only 2 gigs of RAM, hard drive can be replaced only in a extremly crazy way (you need to take the whole mac mini apart to replace it with other hard drive or SSD).
- Macbook white - 759 . Same hardware specs as the mac mini. Hard drive replacement much easier according to ifixit.com pictures.
- Macbook Pro 13" 2.3GHz - 1199. A lot more pricy than the other 2 solutions, on other side it's Sandy bridge and 4 gigs of RAM. The issues - another 28-29 for the DVI or HDMI adapter, it has compatibility problem with selected SSDs (Crucial c300/m4; Intel 510; some reports the same issue with Vertex 3 as well). The SSD compatibility issue should not be that big of a problem, i could upgrade the SSD in my main PC instead and put my current Corsair Force in the MBP.
- The remaining options are either too expensive (MBP 15/17) or useless (iMac, Macbook Air, Mac Pro, mac mini server).
