Just so we know what we can place on top of the case, what is the weight that can be supported by the top of the case?
I'm asking for those with larger monitors.
I wouldn't put anything bigger than a blu-ray player/SAT decoder/console on it unless the covers were somehow strengthened to not bend.
Either external or internal structure has to be able to withstand such weights as monitor and it doesn't look like any of them will from the photos.
I'd change the OP then, because you show of the case with a monitor on top.
I think you mistook saper for me![]()
The second prototype will have steel interior and a thicker aluminum exterior. There is also extra support built in so that weight is better distributed.
I didn't mean the materials, though a really thick sheets of aluminium on the outside might work but the interior in general looks like a really fragile thing. That extra support needs to be a huge change of for the internal design to work for such big monitors.
I still don't get it - why is the power button on the bottom side?
I want this NOW. You had me sold with the photo with all the drives, exactly how I would use this.
hows the Gigabyte Brix. How is its performance?
I'll be working extra hard to get it to you! Are you planning to make a NAS/Media Server? Would you be using a RAID card?
NAS/Media Server/HTPC and no RAID card.
I understand that the GPU is partitioned away from the rest of the system--would it be possible to do the same with the radiator? I'm thinking radiator pulling in air through a filter, and all that air being pushed straight out the vents on the side/back. All else fails, I guess I could 3d print a partition myself.
Would be nice if the case fit a 280mm radiator too, which would pretty much allow two 120mm radiators because of the extra space necessary, but I guess it's understandable with how small you're trying to make this case.
Also, looks like (although it'd definitely be a tight fit) I could fit a custom loop in there with a 240mm rad, if I used a SSD positioned as close to the PSU as possible and put the pump in the remaining space. Or, if the gpu partition could be used as an alternate mounting location for 2.5" drives, that'd be perfect.
...oh, the possibilities.![]()
I think the GPU compartment already has mounting locations for 2.5" drives.
Any updates when you'll be ready to sell them to the public?
What's up with the 2 dents along the bottom front edge?
Looks great--I'd love to have one of those under my monitor on my desk...different color, though.![]()
It's where the top panel is attached to the frame most likely. that's also on the renders.
I'm wondering how cpu coolers upside down will run in general. I checked the iFreilicht's idea for our case to turn it upside down and the intel fan makes chirping noises that way.
Interesting. I hope this is just a quality of the intel stock coolers and not a universal thing. I will check with a few other low-profile coolers. Air cooler tests will probably come later though; I want to do water cooling tests first![]()
Am i the only one who's OCD is going crazy over those "random" holes on the front.
The ones on the side aren't as bad, but i'd still prefer some sort of symmetrical order to the hole pattern.
I don't think the holes next to the PSU are wasted--there should be at least 5mm of space there, which is plenty for a fluid to squeeze through (fluids are funny like that), but I'm not an expert in these things, so I could be wrong. I agree that maybe the ones on the front shouldn't end so abruptly, but I'm not sure that they'd really help that much, and it may not look as good.
When put together it looks okay but I actually don't like the idea of mounting half of the components on the panel that's detatched. There'll be a lot problems with too long cables going into fan areas and general cable management because of that.
That's of course if you don't have some fancy idea on how to tackle this. Otherwise you'll end up with multitasking the cable management while putting this panel on.
I know we have to compromise somewhere when building in this format but this part of cable management that makes cables clear of the fans is crucial since you're going to screw this all up together and then upon firing it up you'll need to reopen the whole thing.
I think a channel for cables to run through would be nice, but it's not really necessary--some cable tie mounts and double-sided tape should be fine for cable management. It looks like you should only need about five inches max for fans over the video card, maybe 10 inches for the radiator fans, with that panel on it's side next to the bottom panel. You'll probably need extensions for the fans, and long sata/power cables for your drives, but if you run all of your cables along the panel (rather than floating in air) and your cables are long enough you shouldn't have a problem with cable management.
What would be a concern for me is whether the clc's block would reach the cpu and be easy to put on while balancing the panel--I don't think there's an easy work-around for that. Looks like there's enough room for an EK XLC Predator, or loops like that--it might not be an issue if you use QDCs.
