WhatTheSchmidt
- Jun 4, 2007
I'm using MSI wireless Utility with my card, the connection is always 90+% and is pretty fast and good most of the time. All of the sudden for no reason I can fathom the connection stops working and the MSI utility will either display connection is good or it will go back and forth with disconnected and connected but not work. I have to right click on the windows wireless connection and click repair. After the repair it works fine for 15+ minutes but the problem happens again within an hour.
What's going on and how can I fix this? Should I try using windows zero configuration?
