HI.
My pc:
9900K 5G OC manually overclocked to 5ghz
LLC level 6,all power limit maxed,sync all cores 50,core voltage was 1.315v. But now actually i bumped to 1.320v to see what happens.
2x16GB DDR4 3000MHZ GSKILL
Asus Prime Z390-A
Corsair 850RmX
Pc is rock stable i think. But i am getting sometimes Whea Logger 19 Internal Parity warning only when i am playing Metro Exodus.
It pop up in event log,like once of 9 hours of play. What can i do now ?
Also get this on new bios and older . Sometimes WHEA LOGGER 19 INternal parity will pop up. Like 1 warning of 9 hours in Metro Exodus. Should i worry?
Its event screen:
I tested 8 hours RealBench stress test 32gb ram and no bsods,no wheas. IHC MEMTEST no errors.
Like i said i bumped core voltage to 1.320v or maybe should i bump too a Dram voltage from 1.350v?
My pc:
Asus Prime Z390-A
Corsair 850RmX
Its event screen:
