Whach
- Dec 22, 2011
If you look at the thermal images in this link it shows that the system is actually running cooler while horizontal. The slides of the cooling design would actually suggest that horizontal is better, and these pictures are a strong argument for that case. It shows that horizontally the heat is being spread out over more area, not being concentrated over the APU. Meaning less corrosion from heat on the internals over time.
The difference in temps is really not enough to argue to the layman that one way is better than the other. But the thermal design suggests that horizontal is optimal. I think they just kept the vertical option for people accustomed to it and for people who need to place it vertically for their own storage situation.
The hot spot on the top side of the console while standing vertically is 116 degrees, while the one sitting horizontally is 114 degrees. The exhaust temperature while standing vertically was 146 degrees, while it is 138-140 while sitting horizontally. The vertical image shows the heat concentrated around the APU on the right side of the console, while the horizontal images shows the heat dispersed across the entire surface area of the case.?? Those images are from the same source. And from that article, vertically is still cooler than horizontally, unless I'm reading the comparative images incorrectly.
As I said, I don't think that the difference in temperatures will really matter when it comes down to placing your console in your entertainment center or desk.
I also have 2 thermaltake mobilefan 120mm USB fans. one blowing on the front of the machine, the other on the underside of the shelf at the rear blowing up to help exhaust the heat as soon as it exits the ps4. fans are USB so they shut of and on with the system.
