Intel's 9th Generation Core Family - Coffee Lake (Refresh)
Discussion in 'Intel Processors' started by Polo6RGTI, Jul 3, 2018.
  1. oleNBR
    oleNBR Limp Gawd
    344
    Dec 9, 2016
    isnt 9700k at similar price but actually offers a bit more performance? why not just get that instead.
  2. Nightfire
    Nightfire [H]ard|Gawd
    1,127
    Sep 7, 2017
    The results for the 9700k were not nearly as good as these estimates, especially with the 4.7ghz "stock" clocks now.
    Clock for clock, I am thinking the 8700k would do better. Actual 9700k numbers shown on right, with updated 8700k numbers. For 720p gaming, the 8700k was about 97% of the 9700k and 98% at 1080p.
    Finally there is live streaming performance. We have seen a slow 6/12 destroy a fast 6/6 so it is not a stretch that a fast 6/12 would still be better than a fast 8/8.
    The first line of the conclusion is that Intel proves that 8/8 is faster than 6/12. That is definately debatable.
    IdiotInCharge likes this.
  3. IdiotInCharge
    IdiotInCharge Not the Idiot YOU are Looking for
    7,944
    Jun 13, 2003
    Yeah, it should be, for nearly every workload- and shouldn't be appreciably slower when it's not, but could definitely be faster with eight FPUs versus six on the 8700K in FPU-intensive applications that are well-threaded. That would include some games and content creation workloads I'd think, so the 9700K is perhaps more desirable clock-for-clock for most consumer uses.
    Stuff that's heavily multi-threaded that's not FPU-intensive, perhaps compiling (SWAG), might be faster on the 8700K clock-for-clock, but no idea how much.
    And generally speaking, the 9700K has a larger die and better solder, so it should be a better out-of-box overclocker too.
  4. Nightfire
    1,127
    Sep 7, 2017
    The 9700k does seem to clock better, but the 8700k is very close if you delid. Even better if you have an 8086k.
    Again, many of the apps did much worse than expected, especially Java and Euler. It is very hard to see where the 9700k is more desirable.
  5. oleNBR
    oleNBR Limp Gawd
    344
    Dec 9, 2016
    some other synthetic benchmark shows a bit more difference, like around 15-20%
  6. IdiotInCharge
    7,944
    Jun 13, 2003
    But are we talking about actual consumer loads?
    I get that synthetics can be representative of actual workloads, but this isn't always the case.
    Nightfire likes this.
  7. oleNBR
    oleNBR Limp Gawd
    344
    Dec 9, 2016
    most consumer load would be within 1% because of clock speed, in that case its IPC theres no improvement. a lot of consumer stuff still only use 1 core btw so this issue always existed, from 6700k to 7700k then 8700k etc
  8. IdiotInCharge
    7,944
    Jun 13, 2003
    Gaming is thread-limited; rarely would the extra threads from HT with eight cores make a difference, unlike how it does at four cores and to some extent six. But other stuff like photography and videography, which with gaming is what I mean when speaking to 'consumer' loads, also probably benefit very little from a benchmark perspective.
  9. oleNBR
    oleNBR Limp Gawd
    344
    Dec 9, 2016
    gaming would also be dependent on thread and clock. if a game uses 8 threads. then 8700k would be 4c/8t at most and it'll loes to 8c/8t big time. if game design to use full cpu resources then 9700k wouldnt be that much better than 8700k. then if a game uses 12 threads, we got full 8700k being used vs 6/8 cores of 9700k.
    but quite honestly i dont care much about games, like 3-5 fps out of 100 is nothing really. but if i were to do say 7zip, winrar, video encoding, browser loading, vmware and i need those to be noticeably faster, which seems 9700k does come out ontop vs 8700k by about 10-15%, thats good enough.
  10. IdiotInCharge
    7,944
    Jun 13, 2003
    This really depends on the load split between ALU usage, which is easy to farm off to virtual cores provided by hyperthreading, and FPU usage, of which is not so easy. Assuming good thread usage, FPU heavy stuff is likely to favor the 9700K, while ALU heavy stuff is likely to favor the 8700K. Further, the difference can be not just application dependent, but workload dependent, and that's where you have to be really careful about the synthetics and line up the specific use cases.
    And this is why I ask about 'consumer workloads'- you have to do a lot of zipping/unzipping for compression performance to make a difference; same for browser loading, which a dual-core CPU is already fast at. Do you reload fifty tabs every few minutes?
    Video encoding is one that I get in addition to gaming, but that also has to be a primary purpose of the system or being done for profit to really be a differentiator one way or the other. VMs I get too- but is a consumer-socketed system being used for dev work or for server work? My homelab server has a 7600k in it and it runs VMs, but the load is still negligible. At what point is two extra FPUs vs. four extra virtual HT threads going to be a decision point there?
    This is why I err toward gaming and video/photo editing: this stuff is more likely to use the extra FPUs on the 9700K, which is what I'd recommend in nearly all consumer cases.
    oleNBR likes this.
  11. Nightfire
    1,127
    Sep 7, 2017
    7zip and rendering were similar despite the 8700k clock deficiency. Video encoding, VMware and "browser loading" seems pretty proportional to the clock speed advantage.
    It is only 10% faster due to clock differences.
    I think Intel sold all of the reviewers a bill of goods with the 9700k. By having MCE-like clocks of 4.7 ghz, it looks better than the 8700k.
    Priced the same, the 9700k is probably the safer route if you don't delid. 5.0 ghz+ seems like a sure thing with moderate cooling. For the delidders, the 8700k and 8086k seem more attractive.
  12. oleNBR
    oleNBR Limp Gawd
    344
    Dec 9, 2016
    man the 9900k gonna be hot in the laptop
  13. Nightfire
    1,127
    Sep 7, 2017
    There was alot of critisism for the 8th gen that some used MCE settings. Board makers were being shady for having MCE on by default in some cases and Intel had no control of this.
    The time around, MB makers seem to be a bit more sneaky. They are giving turbo boost for an infinite time which negates the 95w tdp:
    I guess you could say that this is the new MCE. Do you guys think that this is completely the board makers fault, or does Intel share some blame here? They seem to be encouraging this while still looking good with a lower TDP.
  14. PhaseNoise
    PhaseNoise [H]ard|Gawd
    1,056
    May 11, 2005
    If running fully within stock specs is important for you, you almost certainly won't be buying enthusiast aftermarket motherboards.
    Intel of course is allowing you to do what you want. Run "safe" or run "fast" - you can do what you want. They publish what they certify is "safe".
    Armenius likes this.
  15. Nightfire
    1,127
    Sep 7, 2017
    So do you think the infinite turbo should be considered a motherboard overclock and if not, should TDP still be 95w?
  16. PhaseNoise
    1,056
    May 11, 2005
    I don't like the term "overclock", as basically all computational chips have variable/dynamic clocking now. If you're asking if running with infinite turbo exceeds the specced TDP - yes, absolutely. The TDP spec has limits on time spent at boost frequencies. Blowing past that will mean you're using more power in the steady state, and thus have a new TDP.
    But I have to admit I don't understand why people are upset about the motherboard makers making generally very safe ways of getting higher performance from high end chips. MCE is incredibly safe, as is infinite turbo with even a moderate cooling system.
    Armenius and IdiotInCharge like this.
  17. Nightfire
    1,127
    Sep 7, 2017
    It just seems that Intel is getting their cake and eating it too with this scenario ie, high performance while advertising low tdp.
    What would you consider moderate cooling and do you know anyone or any reviewer that used moderate cooling during this type of MCE?
    ZodaEX likes this.
  18. PhaseNoise
    1,056
    May 11, 2005
    They are advertising a given TDP for the speeds which correlate with that TDP, along with the information that it is unlocked and you can do what you want - including running at higher speeds / power levels.
    MCE will increase the TDP to the ~120W range (reasonably typical). That level of cooling is pretty easy to come by. We're not really shooting up into a specialized bracket at this point, which was what I was getting at.
  19. oleNBR
    oleNBR Limp Gawd
    344
    Dec 9, 2016
    who really cares though the people getting 9900k to run it at stock and stock turbo? honestly i think thats just stupid.
    if we getting 9900k it'll obviously all core OC at 4.8-5ghz when we can, for those who want to run it at stock might as well wait for other SKU thats locked no point paying for unlocked chips.
    and when we OC, TDP goes out the window, not a problem.
  20. Nightfire
    1,127
    Sep 7, 2017
    Yeah I get that, it just seems that there needs to be some guidance by Intel for the MB manufactures. If Intel advertises TDP at 95w, which is around 4.3 ghz, that should be the stock settings.
    Most importantly, not everyone is buying $100+ cooling solution for these. Most likely those using a standard fan rated a TDP will throttle down.
    oleNBR likes this.
  21. IdiotInCharge
    7,944
    Jun 13, 2003
    If it is stable, then there isn't an issue on an enthusiast board. Hell, there's really not an issue at all- if the CPU is pushing into unstable territory, it should throttle down. That's good. Those that are picky about actual power usage have those settings available to them in the BIOS.
  22. Armenius
    Armenius [H]ardForum Junkie
    15,469
    Jan 28, 2014
  23. Armenius
    15,469
    Jan 28, 2014
    Sweating intensifies...
  24. kamxam
    kamxam [H]ard|Gawd
    1,454
    Mar 2, 2005
    Was looking at my B+H order, and it looks like my 9900K may finally be coming soon. (9900K page says in stock) May want to check it if your interested, but it probably won't last long if so.
  25. Nightfire
    1,127
    Sep 7, 2017
  26. IdiotInCharge
    7,944
    Jun 13, 2003
  27. Nightfire
    1,127
    Sep 7, 2017
    For the most part, yes. I think I would fork out a little more for the 8700k. It is a munch more versatile chip. The 9600k looks to be a dissapointment for overclocking.
    In addition, measuring only fps seems archaic nowadays.
  28. Armenius
    15,469
    Jan 28, 2014
    juanrga likes this.
  29. Armenius
    15,469
    Jan 28, 2014
    Couldn't help myself, so I bit on the 9900K. Was going to go for the 9700K, but I had a $500 gift card that the sale created opportunity for and it now has $0.01 left on it :ROFLMAO:.
  30. Lastan010
    Lastan010 [H]Lite
    103
    Mar 2, 2017
    in two years from now you will realize the right and wise decision you have made to go with a 8 core 16 thread cpu, enjoy it.
  31. spiroh
    spiroh Limp Gawd
    339
    Aug 17, 2004
    I've been very happy with my upgrade to the 9900k. With a Kraken X62 I am fully stable at 5.1 using up to 2 cores and 5G using all cores at 1.3 volts. I have not tried all cores at 5.1G yet. Temps go up to 60 deg C . I had to manually set the voltage as the Asus mobo was giving it above 1.6volts in auto mode.
