wtf even supports that?
Coffee lake?
Don't the mobos need to support it? The Apex is only DDR4-4500. MSI Godlike is 4133. etc.Coffee lake?
Why is that exactly? I know that Samsung b-die are good for Ryzen compatibility, however I did not think it mattered much for Intel.Get some good samsung b-die 3200. Trident-Z CAS 14 is a good choice, it's worth the extra couple of bucks.
Battlefield series has always been about multicore suport it looks like 6 cores and a higher clock speed works well. The i9 really lagging but well above most of the AMD chips.
8600k is lookin like an amazing Gaming CPU for a great price.
It says -7-8700k not 7980xe.![]()
I already had 2x16gb gskill rgb 14-14-14-34 3200 and i bought a second kit. I went with the board due to the 3 m.2 i will be raiding 2 nvme drives and i have a SATA. I do like thelook as well. REALLY hoping it will work with 4 sticks of ram and my Kraken x62 and allow me to fit all 4Hi Luke. I'm going to get the same combo, thank you for pointing it out. Can you tell me what RAM you are going to get with it? Also, what drove you to this motherboard? I'm liking the Audio specs.
Only problem is the K doesnt get you as much as it used to, the techreport review althought not including temps that I could see says 4.8ghz on air for 8600k. Which is the other thing with the newer cpus they dont OC like the old ones, since they basically have just built in higher clocks. 19% OC was easy for ivy bridge on stock volts now your looking at 12% on air easy
No so sure about that unless I just got a golden CPU. And this CPU did not come from Intel.Yup agree 100%.. My 6600k is OC'ed by 1000mhz... and its performance is pretty much identical to all the 4 core lake ( sky, kabe, coffee) CPUs... at the same clocks of course.
personally I think the 8700 with an H series Mobo will be a winner. Unless they allow multicore turbo to work on z370 which at least 1review it doesn't work with the 8400Thinking about upgrading the 'other' computer - 2500K not performing well anymore in newer games (at 4.3 OC).
Worth the upgrade? Thinkin 8700K, but 8600K looking good. Regretted not going with HT before though.
Pretty sure he's saying that he got lucky with the CPU oc'ing so well.What are you saying?
Also is it recommended to use Windows 10 for the 8700k? I have one coming in either tomorrow or Saturday hopefully and I haven't left Windows 7 yet.
Time for you to pack up your shit and move on! Windows 10 is solid.Pretty sure he's saying that he got lucky with the CPU oc'ing so well.
I am saying that I have no reason to believe that the CPU I am using is much unlike any other. UNLESS, just by luck I got a golden sample, but I only have one so I have no idea.Pretty sure he's saying that he got lucky with the CPU oc'ing so well.
It probably still works. You might have trouble during install with USB3 and you might have to go directly to Intel's site to get some mobo drivers.Pretty sure he's saying that he got lucky with the CPU oc'ing so well.
December? That's not too bad. Only a few months after that will be a new Intel/chipset to buy!Order placed (LDLC.com) for 8700k + 32GB of DDR4 (OUCH! but I really need it) and a Gigabyte z370 AORUS Ultra Gaming. Mobo and ram are in stock but for the CPU they say "December". But maybe they just have no idea.
December? That's not too bad. Only a few months after that will be a new Intel/chipset to buy!![]()
And possibly Ryzen 2!!! Wow december......Well yea Intel just did a paper launch. Man TBH it really seems like Intel is worried about Ryzen sales indeed.
Been rocking this screen name for the past 25 years, half my life (yeah, old fart at 50 here)...
When I look at your screen name, I immediately think of the phonetic alphabet (T = tango) & the Navy SEALs, hence the chuckle I got from the tacticool comment...!
Was not trying to bust your balls, just found it funny...
Stock? Wtf does that have to do with anything?Isn't the 6600k 3.5 stock? I have mine OC'ed to 4.5mhz atm. All the Lake CPUs have the same IPC.. At the same clocks there performances should be margin of error. If all CPUs are 4 core obviously.
Correct me if I am wrong, but isn't Ryzen 2 in 2019?
TBH who knows. Like I said it was coming from a PR standpoint. So who knowsLikely yes, I think Pinnacle ridge and/or any update to RR will be the update through 2018. Maybe Q2 2019 for Matisse
Assuming no issues with the 7nm then 2019 is the likely release, i think 2019 was a conservative push back in case of the aforementioned
Yea. I try not to take PR from any tech company period. I mean shit lets not even mention this current Intel release which is basically a paper launch.
Now IF Ryzen comes out with the 2000 refresh in Q1 2018....that will throw a wrench in Intel's plan.
A few months back pinnacle ridge was slated for Q1 say Q1/Q2 conservative it is a good time to realease early in a year.
PR has some low lying fruits to tweak, the ultimate challenge will be tosqueeze higher turbo policies, most ryzen out the box push like 3.5-3.5 allcores and 4ghz max which is to low
