HarderThanIThought
- Nov 8, 2014
Hi
I am looking for some good 120mm PWM fans, preferably comparable in performance to Corsair SP120's PWM Hi-Performance (63 cfm @ 3.1 mmH2O), but which are compatible with the "Intel PWM Standard". I am reliably informed that the Corsair PWM has incompatibilities. This may be causing me issues with my X99 Deluxe mobo.
An extreme bonus would be if they fit with a black and white colour scheme a la the Corsairs, but I appreciate that makes the odds vanishingly small.
Thank you
Thank you
