Ieldra
I Promise to RTFM
- Mar 28, 2016
Need to consider like I mentioned before we have no idea where the CPU and motherboard came from for both the Hexus and Bit-tech review because they are outside the NDA, meaning they borrowed these from some source and not necessarily good examples.
Case in point Hexus has a different result to Bit-Tech and hitting 100c when going to 1.3V rather than lower voltages like Bit-tech
In fact 1.25V in the Hexus review managed 4.7GHz all cores with a Noctua D15S, they then swapped it out to do higher voltages towards 1.3V with AIO.
Never know could be something to do with the motherboard/BIOS and pushing too much voltage in the Bit-tech review (happened in the past), Hexus results seem to align more with Der8auer and what was hinted by 8pack at overclockersuk.
But yeah really need reviews where everything is using current HW/BIOS/etc, for loaners and reviews outside of the NDA not sure that can be fully relied upon.
Cheers
At the end of the day they are two samples, with preliminary bios etc and they are reaching 4.7GHz on all 10 cores. That is the news here really
The 10 core 7900X at 999$ is already rather pricey, but the 8core is looking really good at this point. With a good sample you can get 5Ghz on all cores on water and that sounds really sweet
