CompMage
- Sep 7, 2003
Great review, can't wait to get our hands on the hardware.
Can anyone confirm the 8/14 sale hold on the 6700K?
Does anyone know how well the 5775C model overclocks? If it can tighten the mhz gap to within a couple hundred mhz then it could be amusing to make a comparison.
One thing we did not use at all on this Skylake CPU was the integrated video. I was told specifically to not expect to overclock this CPU for much anything if I was using the integrated video. It is HOT and will kill your chances of getting some decent overclocks.
to those comparing skylake to broadwell in gaming, the reason the broadwell does better sometimes, is due to the larger L4 cache. Honestly though from a gaming standpoint as long as you have a I5 2500k or better you should be just fine. Productivity is another story though.
I am wondering how skylake compares to older cpus, especially sandybridge, in real world gaming situations where users will run games at 1080P at least?
I'd like to see a comparison of 2500 or 2600 k clock for clock. Maybe 2600k and 6700k at 4.5ghz.
Zarathustra[H];1041776987 said:
Hey Kyle, if you were going to upgrade a gaming PC from SB right now, would you go with the 6700k or the 5820k? With the price being about the same for both platforms, I'm wondering if going the 6 core route might be worth it down the line now that DX12 is officially out.
Oh, it's not just SweC. TechReport shows similar differences:
http://techreport.com/review/28751/intel-core-i7-6700k-skylake-processor-reviewed/8
It's more games than Civ, of course.
So there does seem to be a divide. Sites that show some discrepancy vs sites that show little to none.
desktop process innovation has really slowed down over the past few years. ive been running a 4770k since a few days after launch (june 2013). 2 years later and this cpu at best 5-10% faster?
that said there are some improvements on the chipset that would defiantly make this a good upgrade for x58/z68 users.
Eh check some of the review benchmarks from Sweclockers that Finrep pointed out
http://www.sweclockers.com/test/20862-intel-core-i7-6700k-och-i5-6600k-skylake/17#content
Seems compelling enough of a reason to me.
You did read the review?
The biggest difference that I can see is at 720p and closes as resolutions increase. Who games at 720p? Sure, its not top dog, but not compelling enough - at least for me. New features are nice, but performance is not one of those reasons I'd consider for myself.
I might have missed it, or maybe it wasn't explicitly stated, but this solution has full compatibility with NVMe?
Also, this is the first time I'm really considering a 2500k upgrade. Or at least rig rotation, this replacing the standard bearer and the 2500k being used as a 2nd machine.
Would have been nice to see some 1080p gameplay tests. Is there any reason to upgrade my Ivy Bridge for gaming? 640x480 is not a resolution I play at.
Hi yes sorry I did I should've been more specific I meant at 1080 P. Games are very impressive at the 640 and I know why they did it that way to show CPU difference but I'm not sure how practical that will be at real gaming resolution
Is there any word on when we will actually be able to purchase these bad boys? August 14th?
Yes, Z170 motherboards support NVMe. So do many Z97 and X99 boards with a BIOS update.
This is major for me. I am really looking forward to an NVMe drive.
After seeing the sm195 though, I feel like it I need to wait for one or two more iterations.
Of the drives, or the interface, or the bios support?
I feel like it's a safe bet with either an x99 or X170 since you get 4x3.0 with either platform and I see that as being "enough" for the next several iterations. Also I'll probably hold off on buying a M.2 card until the prices drop a bit.
I still think I'm good enough with my 4.5GHz 2600K, this doesn't really seem tempting for the money needed to upgrade.
I think the motherboard side is good, but after seeing the reviews on the sm195 (to my knowledge the only m.2 NVMe drive), I think I'll wait until I see one or more two versions of it. Samsung has said they are going to incorporate NVMe tech into their 3d storage tech. That would be the one I want.
I'm on an ancient 920 @ 3.8ghz on an evga x58, and planning on jumping to Skylake. But will still likely keep it around as an htpc or server. It's been insanely resilient over the years.
But I've been missing the modern platform stuff like USB 3 and Sata 3. Need to finally pull the trigger. If only the 6700k would go on sale somewhere ...
I'm curious about this iGPU comment in the review:
Does that mean using the iGPU for gaming or using it at all? With my current setup I use 3 monitors. I only game on my main monitor, the other two are just for extra random stuff. Two are hooked up to my first GTX680, and the 3rd is hooked up to my onboard Intel GPU.
Would even a light usage scenario such as that impede overclocking ability?
