mlambert890
- Jan 8, 2007
I thought ivy bridge is gonna be the tock, and SB is the tick.
Nope
http://www.intel.com/technology/tick-tock/index.htm
32nm was already here before SB. Its measured mainly by process efficiency. Ivy is 22nm and, to be honest, a much bigger deal than SB.
Thats not to say SB isnt a great part and a terrific value and very much in the "right direction" (better power/watt, better power/$). Just that its on the 32nm process the same as the i980 and the Xeons and is mated with a mainstream chipset. Nothing wrong with that... Just isnt the "tick". For folks who normally buy mainstream, buy now. Folks who normally dont (and are looking for tri-channel DDR, etc) try to resist. Otherwise you will buy now, see minimal gain over your current (most likely heavily overclocked i7/1366) and then buy again when Ivy drops.
