Intel Rumored to Launch 9th-Generation Processors on October 1st
Discussion in '[H]ard|OCP Front Page News' started by Megalith, Aug 12, 2018.
  1. Megalith
    Megalith 24-bit/48kHz Staff Member
    12,754
    Aug 20, 2006
    Wccftech has a source claiming Intel’s 9th-generation Core processors will arrive in less than two months. These comprise the i5-9600K, i7-9700K, and i9-9900K, the first Intel chip with 8 cores and 16 threads.
    According to the embargo document, Intel would first release the unlocked SKUs, which would eventually be followed by the rest of the 9th-generation family in Q1 2019. In the previous slides, we also saw that compatibility will be retained for 9th-generation processors on current 300-series motherboards along with the new Z390 platform.
  2. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,174
    Oct 5, 2004
    Yeah, I'll have my Asus ROG Hero Maximus WIFI updated and inline with my $500 dollars at launch.
    Goal is to delid and have my 9900K at 5GHZ across all 8 cores.
    DPI and ZeqOBpf6 like this.
  3. Sparky
    Sparky 2[H]4U
    3,186
    Mar 9, 2000
    I dont agree with that. 5960x has it and also more L3 Cache.
    blandead, N4CR, shatterstar and 5 others like this.
  4. James Robinson
    James Robinson Limp Gawd
    288
    Dec 4, 2016
    Seen several 'press releases' about Intel and what MIGHT be coming 'soonish'.....
    Sorry, sounds more like hype released by their Damage Control squad after so much shit press involving their products... I'll believe it when It actually happens.
    N4CR, Darth Kyrie, IKV1476 and 7 others like this.
  5. R_Type
    R_Type Limp Gawd
    154
    Mar 11, 2018
    Oooh Intel really are running scared these days. Good for us though!
    MatthewK, N4CR, Stimpy88 and 3 others like this.
  6. Hagrid
    Hagrid Kyle's Boo
    7,874
    Nov 23, 2006
    Not sure what they mean then. I am also sure that my 5960x has 8/16, and solder.
  7. Makaveli@BETA
    Makaveli@BETA 2[H]4U
    2,300
    Mar 24, 2004
    Considering the all core turbo will be 4.7 even with the silicon lottery I think that is doable.
    What are you using for cooling?
  8. Nukester
    Nukester [H]ard|Gawd
    1,411
    Mar 21, 2016
    Are these Spectre and Meltdown free? if not, forget it.
    John721 and Stimpy88 like this.
  9. artforz
    artforz n00bie
    15
    Mar 24, 2017
    If you only count unlocked retail CPUs, that'd be E5-1680v2 on x79.
    Otherwise, E5-2650/60/70/...
    Ranma likes this.
  10. Makaveli@BETA
    2,300
    Mar 24, 2004
    I don't think intel will have any cpus out this year that are fully patched in hardware.
    John721, Vercinaigh and LightsOut41 like this.
  11. Denpepe
    Denpepe Gawd
    841
    Oct 26, 2015
    Someone forgot the word "mainstream" in his newspost :giggle:
    techie81 and auntjemima like this.
  12. Krenum
    Krenum [H]ardForum Junkie
    14,609
    Apr 29, 2005
    Could finally be time to upgrade my 6700K come the first of the year.
  13. It's a bargain at $500 with a $75 chipset *snickers*
  14. viper1152012
    viper1152012 Gawd
    996
    Jun 20, 2012
    I'm holding off until some kind of hardware patch is worked into the chips. I know there will some later expoits but I woukd like some movement on the future of chip security.
    Scares me a bit.
    Jovian likes this.
  15. SixFootDuo
    5,174
    Oct 5, 2004
    H115 Pro RGB
    I have the delidder and liquid metal already.
    I just need some balls of steel at the time of delidding and I'll be ok ... I hope
    Makaveli@BETA likes this.
  16. craigdt
    craigdt Gawd
    901
    Oct 27, 2016
    I cannot imagine the heat this thing will produce.
    My 8700K was at 85C running Handbrake yesterday with an AIO cooler and a -3AVX offset.
    Will be a monster though. Tempting, since it should be a drop-in upgrade, right?
  17. Ranma
    Ranma Limp Gawd
    165
    Jan 31, 2008
    The E5-2670 has more L3 cache at 20 megs, the same as the 5960x. It was I believe among the first 8 core and 16 thread Intel chips, and that's going back to Sandy Bridge ie 2012!
  18. Kenjiwing
    Kenjiwing 2[H]4U
    3,679
    Apr 6, 2009
    any idea when the i3 shit will release?
  19. exlink
    exlink 2[H]4U
    3,843
    Dec 16, 2006
    I'm assuming they meant the first 8c/16t Intel CPUs on the "mainstream" platform and not the HEDT platforms like the x99 and x299. Either way it was poorly worded.
  20. jamesv
    jamesv [H]Lite
    99
    Mar 12, 2016
    It’s whats kept me away from AMDs.
    Intels chips with 95 Watts or less are as high as I want to get.
    I want AMD or Intel to have a base of 4.5-5GHz and 4 Cores @ 65 Watts.
    After the Core Wars perhaps.
  21. Ranma
    Ranma Limp Gawd
    165
    Jan 31, 2008
    You know you can always buy a T series Intel chip, or even one of the low power AMD varieties that are coming out. I mean even the Ryzen chips are only 65W at 8 cores if you don't get the x series. An 8 core chip at 4.1 will do you more good than a 4 core at 5 if you're doing more than playing dumb games :) haha
  22. NKD
    NKD [H]ardness Supreme
    7,116
    Aug 26, 2007
    Rumor is intel is finally not doing a crappy job on these and you won't have to delid these processors. I think I read somewhere these might be the first chips where they are soldered on or not using crappy tim or something. That is probably why these are running at 4.7ghz all core boost out of the box. I don't thin that would have been possible out of the box if they were doing the same old crappy jobs.
  23. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    20,829
    Sep 13, 2008
    the 9900k's are rumored to be soldered which is probably the only way they were able to get the boost clocks they're claiming so you shouldn't have to delid it.
    NKD likes this.
  24. jamesv
    jamesv [H]Lite
    99
    Mar 12, 2016
    Not with apps I use inside of 1U Chassis.
    More Cores is more latency.
    I’d take a Dual Core @ 6GHz over an i7 8086k in a heartbeat.
    From my experience Intel is full of crap on watts of low power aternatives.
    I had an i7 4770S. They said lower watts and @ 400 MHz slower who could deny that.
    15 watts higher than they claimed and it wasn’t locked.
    Took it to 4GHz and it was hotter than if I would have bought the k.
    Just a lower binned product hyped up to save Earth from global warming.
    Ranulfo likes this.
  25. Stimpy88
    Stimpy88 [H]ard|Gawd
    1,208
    Feb 18, 2004
    I cannot see the point in helping Intel make more money, while Spectre and Meltdown go unpatched, yet again.
    They simply should not be allowed to sell unpatched CPUs without a warning on the box that tells you once you patch your system, you will loose performance with this product.
    MatthewK likes this.
  26. Factum
    Factum [H]ard|Gawd
    1,406
    Dec 24, 2014
    Isn't the i9 9900K 8C/8T...aka no HT "cores"?
  27. sirmonkey1985
    20,829
    Sep 13, 2008
    That's the 9600k
    Both sides are full of crap when it comes to tdp ratings.
  28. Malurt
    Malurt n00bie
    21
    Jul 12, 2016
    What? Intel keeping socket compatibility? This can't be right.
  29. IdiotInCharge
    IdiotInCharge Not the Idiot YOU are Looking for
    7,899
    Jun 13, 2003
    The 8C/8T part is actually the 9700K- which is a direct replacement for the 8700K.
    [And I'm not convinced that losing four threads for two more cores will be an overall improvement like it largely was with 7700k -> 8600K going from 4C/8T to 6C/6T]
    The 9600K will be a slightly-higher clocked version of the 8600K with 6C/6T.
  30. IdiotInCharge
    7,899
    Jun 13, 2003
    Looks like they planned ahead with the power distribution, unlike AMD with their 300-series and many boards that do not like running the higher-power parts at higher speeds.
    [CPU forward compatibility is always a gamble and one that you usually lose; either you enable it for the boards that may support it and deal with the issues surrounding the boards that don't, or you spin a new release with guaranteed compatibility and piss of a few people on forums that whine about something that they were never guaranteed :D ]
  31. Factum
    Factum [H]ard|Gawd
    1,406
    Dec 24, 2014
    Depends on what you are doing with the core, I am looking at the 8C/8T part when more info is out.
  32. katanaD
    katanaD [H]ard|Gawd
    1,872
    Nov 15, 2016
    is this going to be a paper launch, or a product is able to be bought launch?
  33. IdiotInCharge
    7,899
    Jun 13, 2003
    Could be a bit of both- demand was so high for the 8700k that you simply couldn't find one, despite there being significant channel supply.
  34. N4CR
    N4CR 2[H]4U
    3,247
    Oct 17, 2011
    Yes at times.
    Recently THG tested Xeon vs Epyc and in one test the Xeon smashed past it's TDP by 100W! AMD actually stayed within on all tests.
  35. jardows
    jardows [H]ard|Gawd
    1,318
    Jun 10, 2015
    So many rumors, so few announcements.
  36. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    26,514
    Oct 29, 2000
    Will be interesting to see how much more they can squeeze out of their aging 14nm process...
  37. IdiotInCharge
    7,899
    Jun 13, 2003
    I'd thought I'd killed my 8700k... turns out it probably still isn't the best sample, but physical pressure on the RAM from being installed tightly next to a radiator fan was causing some really weird shit.
    However, since I'd upgraded the board to grab the version with the 10Gbase-T Aquantia NIC (working great with an HP switch, by the way!), I now have a 'spare' Z370 board, and both of these ASRock Z370 boards (one Killer SLI/ac and one Professional Gaming i7), I might consider migrating my server build from a surprisingly rock-solid 4.7GHz 7600k to my 8700k, and then put a 9900k in my desktop...
    ...and with an H115i, I'm not really worried about power draw/heat, on the CPU at least :D
  38. Joust
    Joust [H]ard|Gawd
    1,745
    Nov 30, 2017
    Seems like everyone is using the AIO coolers. I gave up water loops years ago and use a Noctua. Similar results for CPU cooling in my experience. Obviously GPU and other heat syncs (used to do a Northridge cooler, etc) is a big YMMV.
    Meh. I don't claim to be [H]ard. Big {S}ofty here.
  39. IdiotInCharge
    7,899
    Jun 13, 2003
    I'd consider them about the same for most installations. My H115i is dead silent with any load that I can throw at my 8700k, but so is my buddy's under a dual-fan Noctua tower.
    Main difference to me is how much space those take up inside around the socket, and that the hot air still needs to be exhausted, versus a positive-pressure setup using AIO coolers on the exhausts.
