Intel RMA does this sound right to you?
Discussion in 'Intel Processors' started by BrokenAnimator, Jan 3, 2018.
  1. BrokenAnimator
    BrokenAnimator Limp Gawd
    169
    Dec 11, 2006
    howdy everyone,
    So I am trying to RMA a 6800k i7, for some reason intel is saying that my Gskill ripjaw this ram here: https://www.gskill.com/en/product/f4-3200c16d-16gvk
    Is incomparable with my cpu and burned out the memory controller? What? Building computers for over 15 years now, this seems highly unlikely to me.
    Here is the email from them:
    *start quote
    Thank you for your response,
    I'm afraid that the RAM frequency you were using is not compatible with your CPU, the max frequency supported by this CPU is DDR4 2400MHz you can confirm this information on the following link under "Memory Specifications": https://ark.intel.com/products/94189/Intel-Core-i7-6800K-Processor-15M-Cache-up-to-3_60-GHz. The Intel® Core™ i7-8700K Processor does not support that frequency as well you can check it on the following link: https://ark.intel.com/products/126684/Intel-Core-i7-8700K-Processor-12M-Cache-up-to-4_70-GHz
    So you might have burn the memory controller of the CPU by using a not supported RAM kit, this will automatically voids the warranty since is considered as physical damage. However we can try to go with the option 1 (SWR) and once the CPU arrives into the depot they will scan it for physical damage and if there is not then they will send you a replacement.
    Let me know how would you like to proceed,
    *end quote
    Can anyone shed some light on this? I just built a new 8700k with the exact same ram that has been rock solid for 2 weeks now!?
    Thanks,
  2. Speedeu4ia
    Speedeu4ia Limp Gawd
    392
    Aug 7, 2017
    Total BS, but I have read some of the responses on their forum for technical issues and like this it seems like some typical garbage outsourced support.
    BrokenAnimator likes this.
  3. ryan_975
    ryan_975 [H]ardForum Junkie
    14,195
    Feb 6, 2006
    The officially supported max RAM speed is 2400. using faster ram overclocks the memory controller and is not supported. Anytime you overclock a component of the system, you run the risk of burning something up. Since they know you were using out of spec RAM, they can deny you warranty coverage if they can show that there is damage to the memory controller (and I'm sure they have the capability to do so).
    drescherjm and revenant like this.
  4. BrokenAnimator
    169
    Dec 11, 2006
    I agree speedeu4ia.
    Ryan_975 the system in question was never overclocked.
  5. Master_shake_
    Master_shake_ [H]ardForum Junkie
    9,673
    Apr 9, 2012
    it's a standard CYA.
    good luck to you i hope you can get this resolved.
  6. auntjemima
    auntjemima [H]ardness Supreme
    5,158
    Mar 1, 2014
    He never said it was. You are confused between memory controller speeds and CPU clock speeds.
    When using ram that runs at a higher frequency than 2400 you technically "overclock" the memory controller. This isn't debatable.
  7. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,837
    Jan 1, 2008
    What was the symptom of the failed CPU? Memory issue or something else? If the memory controller really is fried, that sucks and it’s the unfortunate risk of overclocking. Notice how all motherboard makers list RAM speeds with a * on the memory support speeds, then the * is listed as an overclocked speed.
  8. BrokenAnimator
    169
    Dec 11, 2006
    You do realize the motherboard controls the ram speed, right?
  9. auntjemima
    5,158
    Mar 1, 2014
    Yes. You aren't the quickest, are you?
  10. ryan_975
    14,195
    Feb 6, 2006
    No, the CPU (on modern systems) drives the clock that determines the memory speed. It's set up by the BIOS during initialization using settings found in the system's NVRAM (which are usually populated from the settings found in the RAM module's SPD tables).
    Once the CPU's memory controller is initialized it is running that the same speed as the memory (otherwise they would be out of sync). So if a CPU supports a max speed of 1200MHz (DDR4-2400), and you're running your RAM at 1600MHz (DDR4-3200), your CPU's memory controller is also running at 1600MHz... thus it's over clocked and not in a supported stated.
    defaultluser and drescherjm like this.
  11. BrokenAnimator
    169
    Dec 11, 2006
    Why be like that?
    Ignoring the obvious trolling or lack of social skills...
    If you did know that this is regulated by the motherboard, then you would know that saying " When using ram that runs at a higher frequency than 2400 you technically "overclock" the memory controller. " is wrong, because you can easily run 3200 ram at 2400 speeds. In fact if you load optimized defaults in the bios it clocks the ram down to 2200 or below by default, which this system was.
    Just because the RAM is capable of higher speeds doesn't mean it runs at that speed, it runs at what is set in the bios, not by what it's speed rating is.
    Point being, that just because you have 3200 ram dosen't mean it's automatically "overclocked", so you're technically wrong on that, and also how you interact with others.
  12. BrokenAnimator
    169
    Dec 11, 2006
    The cpu does not set the ram memory speed. The bios does. Even XMP profiles have to be loaded by the user. At least on my board. Which was never overclocked.
  13. BrokenAnimator
    169
    Dec 11, 2006
    Thank you, I hope so too.
  14. ryan_975
    14,195
    Feb 6, 2006
    I said the CPU DRIVES the memory clock, not sets it. The BIOS pulls the settings from NVRAM and sets up the memory controller (which is in the CPU). The CPU then powers up the RAM and starts driving a clock signal to it so it can operate.
    Now, you never told us that you didn't set the memory up as advertised, and we were left to assume that you were running it at full speed (otherwise, why did you buy it?). Also, whether or not your system actually ran that speed is irrelevant. You said burning out the memory controller is highly unlikely. It's not, and we gave you reasons why.
    auntjemima likes this.
  15. BrokenAnimator
    169
    Dec 11, 2006
    I never said either way because the "k" processors are designed to be overclocked. So to me Intel giving that reason (that nobody knows if this is even the case at this point) should be known to others, as it's basically an easy way out of standing behind their product. It rubs me the wrong way.
  16. ryan_975
    14,195
    Feb 6, 2006
    While K processors can be overclocked, doing may void the warranty. They said they would check the processor and replace it if it's not damaged. That's all you can hope for.
    defaultluser and auntjemima like this.
  17. mnewxcv
    mnewxcv [H]ardness Supreme
    6,475
    Mar 4, 2007
    sounds like BS. Using ram not on a QVL will not void warranty. Technically, overclocking will. BUT, you can run faster ram at supported speeds, and take advantage of tighter timings. I would try to escalate your case and stop dealing with whoever that bozo is offering their 'support'
    John721 and BrokenAnimator like this.
  18. Ocellaris
    18,837
    Jan 1, 2008
    Yes and the CPU is driving beyond it’s designated clocking spec when using 3200 RAM. Hence it’s overclocking.
  19. Gideon
    Gideon 2[H]4U
    2,316
    Apr 13, 2006
    My god the forums on the Intel side are a bit ruthless, I have never seen a memory controller burn out from higher speeds being set, higher voltage is a different thing. Perhaps the better way is to ask the Op, "Did you run the ram overclocked and at higher voltages... If so then yeah they can deny coverage if they find damage due to that."
  20. mnewxcv
    6,475
    Mar 4, 2007
    XMP settings are not applied by default, are they?
  21. Ocellaris
    18,837
    Jan 1, 2008
    Correct, they are always off by default.
  22. _l_
    _l_ I Am A Cock
    1,151
    Nov 27, 2016
    LOL ... "this will automatically voids the warranty"
    If that reply really was from Intel then maybe call or write Intel Corporate Office and report whoever wrote that reply
    John721 likes this.
  23. BrokenAnimator
    169
    Dec 11, 2006
    I am curious, do you doubt that is not from an Intel customer support employee? Try giving their support a call, see who answers.
    They promised me a call back from a manager in an hour, it’s the next day now, never got a callback. I don’t understand how anyone can condone treating costumers this way, even people that spend too much time on forums being bitter shouldn’t be defending a company that does this. As it’s in their own interests to call Intel out on poor support unless they want to be treated the same way when they have a problem,
  24. OrangeKhrush
    OrangeKhrush [H]ard|Gawd
    1,504
    Dec 15, 2016
    The intel warranty is not exempted by K processors, it still is in place and if you are looking to RMA with intel direct you are in for a world of pain. Is it possible to RMA though the reseller that you got it from? They normally do just swap out, while Intel will do everything to not replace it.
  25. Shintai
    Shintai [H]ardness Supreme
    5,691
    Jul 1, 2016
    GoldenTiger likes this.
  26. BrokenAnimator
    169
    Dec 11, 2006
    The ram modules I used (which is the first post here) IS on that list...
    Also that list is not "these components only or your warranty is void", it's for embedded XMP profiles. Which I have stated MULTIPLE times now I didn't even use and the ram was clocked to the default speed of 2133.
    It's almost not worth the hassle to build your own computer anymore as the component makers will look to get out of voiding warranties if you sneeze wrong.
  27. Shintai
    5,691
    Jul 1, 2016
    If you CPU+Mobo+memory combo is on that list, simply attach it to them and tell them you expect RMA process to begin now.
  28. BrokenAnimator
    169
    Dec 11, 2006
    Oh it's that simple? Attach it to what? say RMA to who? I don't think you are understanding that list is supported XMP profiles....not warranty.
  29. Shintai
    5,691
    Jul 1, 2016
    The support person you are dealing with.
  30. BrokenAnimator
    169
    Dec 11, 2006
    Like I said, I called him out on it. He said he would have a manager call me in an hour. That was yesterday...
  31. Shintai
    5,691
    Jul 1, 2016
    Poke them again then :)
  32. _l_
    _l_ I Am A Cock
    1,151
    Nov 27, 2016
    take heart in knowing that Customer service is far, far worst at MSI, ASUS and Gigabyte (can hardly ever even reach a human on the phone there, no email replies).
    List of companies I've received consistent gold star Customer Service from: LG (I remember when they were called Gold Star), Samsung, EVGA, EA, Microsoft
  33. _mockingbird
    _mockingbird Gawd
    992
    Feb 20, 2017
    Glad I went with AMD.
    AMD doesn't even care: if you RMA your processor, AMD will replace it.
  34. Shintai
    5,691
    Jul 1, 2016
    People seem to have plenty of issues getting their broken CPUs replaced there. So that's just BS.
    You can always meet someone with a bad RMA experience, but normally you see fast and easy RMA.
  35. Ocellaris
    18,837
    Jan 1, 2008
    A lot of people had issues getting their defective Ryzen CPUs replaced from early production runs. This was regarding the issue with failing Linux compiles. Plenty of people are sitting on defective Ryzen hardware right now and won’t even realize it. AMD never bothered to open a voluntary recall for potentially defective CPU batches so AMD is nothing if not worse than Intel.
    -Sweeper_, Shintai and Speedeu4ia like this.
  36. gsilver
    gsilver Gawd
    583
    Oct 12, 2010
    Hmm... I did an RMA with Intel early last year without issue. They even offered an advanced RMA.
  37. Shintai
    5,691
    Jul 1, 2016
    They still sell those defective batches in stores.
    https://community.amd.com/thread/215773?start=1875&tstart=0
  38. Gideon
    Gideon 2[H]4U
    2,316
    Apr 13, 2006
    N4CR and Master_shake_ like this.
  39. Shintai
    5,691
    Jul 1, 2016
    Yes, AMD also sell those. Including IBM, ARM, Qualcomm and so on ;)
    Nice try tho.
    razor1, -Sweeper_ and auntjemima like this.
  40. razor1
    razor1 [H]ardForum Junkie
    10,155
    Jul 14, 2005
    Yeah ok, do you even read the white papers by Google before you make such comments?
    This can affect any processor, its the way the branch prediction works, what AMD stated publicly is they don't know if it can hurt their chips, just that the way Google tested it won't work in some cases......
    The interim fix will hurt performance. But the full blown rework (not a patch), which will come later which probably won't have the performance hit.
    Guys damn, just read this shit, not hard to find.
    Shintai likes this.
