GregRotter
- Mar 21, 2010
Stop using AS SSD tbh. I've just gone back to the intel ones, just to see what's the deal. If I don't like it after a few days, I'm going back to the ms ones, again.
are you running raid-0 with the 80s if so maybe your getting degradation
hmm i can't seem to find this as cleaner....
My recommendation skip the raid for now until trim works in raid or untill they make a dedicated ssd raid controller .
My Setup loves io request very snappie happy
SSD C: windows
SSD D: Games
Downloads ,utorrent , limewire , internet download manager
HDD E: Storage
HDD F: Storage
Yeah, I may add a 2nd 80Gb drive when I start getting cramped on my 1st one or when Intel adds SSD Raid support. But since I haven't been gaming at all lately my OS drive is pretty bare.
So my set up is just
C: windows & apps
D: storage (2x640Gb Blacks - Raid 1)
SSD C: windows
SSD D: Games
HDD E: Storage
HDD F: Storage
Your wrong and right , that's what the new drivers are all about supporting your ssd in ahci with your HDD running raid and you still using TRIMOk...I wouldn't mind separating my 2 SSDs...but I still wanted to raid 0 my 2 1TB Blacks.
Correct me if I am wrong, but in doing so I still wouldn't have the trim capabilities unless it is in AHCI.
you are not supposed to defrag SSDs, that's what TRIM/GC is for.
Does mean also can't support TRIM under SSD Raid 0?
Why is that? SLC drives are only needed in server systems with excessive writes. For all other purposes, MLC does fine whether in RAID or not.I.E. most people that I can think of would have no desire to run a MLC drive in RAID anyway.
Looks like version 10 is out http://www.xtremesystems.org/forums/showthread.php?t=259658
The TRIM command specification is being standardized as part of the AT Attachment (ATA) interface standard, led by Technical Committee T13 of the International Committee for Information Technology Standards. A TRIM command allows an operating system to tell a solid-state drive (or "SSD") which data blocks are no longer in use, such as those left by deleted files. You should use the OS build-in ATA command device driver to communicate the ATA port for TRIM command. But, most of the RAID adapters emulate the SCSI command to support more volumes on one RAID adapter. That's why the TRIM command can not support on all vendors of RAID adapters. NetAPP just proposal the Trim command for SCSI spec to T10/10-084r0 and 079r0 on 2 March 2010. It may be included the Trim function on the OS in the future. This is the only method to add the function on the firmware level.
