Intel processor architecture (for Debian install)
dom23
I am planning to install Debian onto an Intel Desktop board.
The website gives me these options for processor architecture:
It is clearly not AMD, do I go with i386? (reminds me of x86). Attached is a photo of the board.
kirbyrj
I would go with AMD64 as that is the x64 version. i386 is the x86 (32-bit) version.
Although, that board doesn't look terribly new, so you might be using 4GB or less of RAM, and then x86 would work also.
Nobu
If it's a celeron, go 386. If it's core2 or newer pentium, amd64.
dom23
How do I find the specific model?
Also gave the thing in the photo a SATA drive and 1 GB RAM, connected to power and a computer screen, yet computer screen is not reacting despite the board being powered.
Nobu
I see a serial number in the bottom of the photo, but can't find the model. Might be on the back or rear io
dom23
https://ark.intel.com/content/www/us/en/ark/products/56462/intel-desktop-board-d2500cc.html
Looks like it's that motherboard based on the sticker on the memory slot. Hard to say about why you're not getting a video signal.
Thank you, that does look like the board indeed.
As to the lack of video signal, I am attaching two photos - in one you see the green light showing the board is connected to power, yet no video signal to the screen. Maybe it needs to be jumpstarted somehow.
Nobu
Looks like you're missing four pins on that power connector. I'd have to look in the manual, but those may be required to power the motherboard/cpu.
Sorry, saw that before, but the pico-psu threw me off and I wasn't sure what I was looking at.
dom23
I have photos of a previous setup from years before with the same or similar board that left those four pins free. See below.
Nobu
It may be okay, it is a low power chip. I just thought I'd mention it in case you hadn't already considered it.
Reactions: dom23
kirbyrj
Did you short the power switch pins on the motherboard? I'd think it wouldn't "turn on" until you did that. It wouldn't just turn on by itself (well, it might depending on the bios settings).
dom23
Where would they be? The manual talks about a BIOS configuration jumper block which I have located, or voltage jumpers, but not the power switch pins.
