If you had a single nic pfSense box such as a NUC, would using dd-wrt/tomato/openwrt as a managed switch work instead of paying for a gigabit switch that supported VLAN? Would performance be worse with dd-wrt/tomato/openwrt (my thought is the custom firmware adds overhead vs a vlanswitch)?
If so I suppose then all you need to do is disable DHCP on the ARM router, enable VLAN so that the pfSense box can communicate with the modem. The ARM router can still be used to add wifi to the network with no issues?
thanks in advance, just thinking about solutions for home networking in case a friend wants to upgrade to pfsense
