Correct. According to Intel, including technical documentation, G33 only supports up to 8GB addressable space, and even G35 is iffy on whether it supports 8 or 16. Officially, 16GB of RAM are only supported on G45/P45, and maybe the 43's as well. As you can see, G33/P35 is just fine with 16GB of DDR2.8 gig memory limit of those particular chipsets maybe?
That's the Datasheet for the 3-series chipsets, meaning G33/G35/P35. They actually say that G33 uses a 32-bit addressing scheme and G35 uses a 36-bit (up to 64GB) internally, but both are still limited to 8GB accessible.The (G)MCH supports a maximum of 8 GB of DRAM. No DRAM memory will be accessible above 8 GB.
the g33/p35 was released in June of '07, two and a half years ago, come on...
Yes, it's accessible. One of my compiling sessions hit 93% usage last night, before Windows gave me a Low Memory error- I can't remember the last time I saw one of those.So, the question is: is that extra 8GB "accessible? Time to load up some massive renders or something!
Does this also mean X38 chipsets also support 8GB+ of RAM?
Page 33
http://www.intel.com/Assets/PDF/datasheet/317610.pdf
Yep, I'd say odds are good.The MCH supports 64 GB (36 bit) of host address space...
16GB kit, $330.Thank god!
Now i can finally spend more on ram for my old piece of poo 775 than a brand new i7 setup. lol
Now the question is will they take 4 8gb sticks!
Thank god!
